Subject: Re: looking for a putty with mim shrieking
2/17/17
john Member
not wanting to mix any 2 part type of putty just looking for a putty with good adhesion and a good dry time . whats your favorite ?
2/18/17       #2: looking for a putty with mim shriek ...
CraigM
Automotive glazing putty. Dries like bondo without adding a hardener. I use the stuff from NAPA
Glazing Putty
2/18/17       #3: looking for a putty with mim shriek ...
Leo G
Generally I use Elmer's putty on white wood and when I'm in the finish room I use a putty stick from Mohawk. No dry time at all. It looks like a crayon and you rub it into the defect and use a card or razor to flatten it out. Sand slightly to dull it and paint right over it.
If it's stained you need to pick the right color and you can clear over it.
It's not for big holes. But it keeps the finishing process moving along.
2/18/17       #4: looking for a putty with mim shriek ...
john Member
has anyone tried timber mate putty
2/18/17       #5: looking for a putty with mim shriek ...
Arthur grudko
I have long been haunted by shrieking putty. It causes me nightmarish dreams. Since I started using Mohawk epoxy putty, available in many colors, the shrieking has subsided and so have the nightmares.
2/18/17       #6: looking for a putty with mim shriek ...
Dustin orth
Depending on how big of an area your doing, I have found the solvent based FamoWood wood filler to be the best for us. When the area is a large knot that is now missing, we use a 2 part epoxy for most of the fill, then FamoWood over the top. We do mostly knotty Alder and go thru quite a bit of this stuff.
2/19/17       #7: looking for a putty with mim shriek ...
RobertJ
Arthur is correct. ShriNKing putty gives me the willies.
2/19/17       #8: looking for a putty with mim shriek ...
Matt Calnen
In the last shop I worked at we found out the hard way that Timbermate putty does not like ML Campbell products, to the point that they caused complete failure any place we used it. Just a tip.
2/19/17       #9: looking for a putty with mim shriek ...
We use Timbermate all of the time and never have a problem with ML Campbell products. We use Hi Performance lacquer and Krystal as well as Stealth.
2/19/17       #10: looking for a putty with mim shriek ...
Matt Calnen
We were using claw lock and resistance. Had two jobs we had to redo, and the only places that failed where where we used it. Might have been a bad batch of either finish or putty, but I remember never using the putty again and never having a problem
2/19/17       #11: looking for a putty with mim shriek ...
Matt Calnen
2/20/17       #12: looking for a putty with mim shriek ...
Bart
I'm still looking as well. I've used Famo, bondo and light weight spackle all supposedly non-shrinking. I was really surprised the bondo shrank. I always used that on high end pigment jobs. The last couple I noticed it on the face frames and double up shelves faced with 3/4". In side light they shrank. In the past I never noticed the bondo shrinking. Done the exact same way with different results. Go figure.
2/21/17       #13: looking for a putty with mim shriek ...
Jim Clark
Most of these fillers do a lot better if you
allow a couple of days before sanding.
Most of us don't have the time, I know.
2/24/17       #14: looking for a putty with mim shriek ...
Bondo definitely shrinks in the first 24 hrs. Its best to fill it high. Wait a couple of hrs. Chop most of it off with a sharp chisel. Leave it over night then sand it smooth.
Otherwise you will get telegraphing thru finishes. Fibreglass boats are built with the same polyester resin and fillers as bondo. They can takes months to finish shrinking.
The rule of thumb is if its still stinky(styrene) then its still curing and shrinking.
We got in the groove with bondo for screw size holes(which are extemely rare). Then one quick coat of primer. Fill any defects with Muralo Pro Spackle(totally different from all the other spackles). Sand and reprime. If you need speed go for a heavy prime coat and then fill the defects with Spackle.
