Subject: Re: How to tell if WB has frost damage
3/3/17
Eric Member
Hi,
Because of a mixup my shipment of Agualente sealer and clear sat out 24 hours in very cold weather. Is there a way to determine if it was damaged without risking my project?
3/3/17       #2: How to tell if WB has frost damage ...
Leo G
If you think it froze scrap it.
• Protect from freezing and other extreme temperatures. This product is unusable if frozen.
• Store in airtight containers.
• Shelf life is 18 months.
3/3/17       #3: How to tell if WB has frost damage ...
Eric Member
Thank you, that was my initial plan. But at near $200 salvaging some if possible would be great.
3/3/17       #4: How to tell if WB has frost damage ...
denny jahnz
Test it on a test panel and see how it performs
3/3/17       #5: How to tell if WB has frost damage ...
Leo G
I would think that it may seem to work fine. But the cross linking is probably damaged. So 5-6 months down the line it'll start to crack or other unwanted effect.
Can you file a claim against the delivery company? Was it there fault that the product was left out in the cold? Did the finish have freeze labels on it?
3/4/17       #6: How to tell if WB has frost damage ...
$200 won't pay for much refinishing if the finish fails, scrap it.
3/7/17       #7: How to tell if WB has frost damage ...
How cold was it? It takes a lot to freeze a gallon of water an a gallon of WB finish would likely freeze slower. Beyond that if it were packed on a pallet (thermal mass) it would be even longer.
I have pushed the boundaries of WB finishes with regards to potlife and of course, its a dangerous roll of the dice, if the containers werent swollen or frozen solid when you popped the lid, Id be a bit skeptical as to whether they "froze" or not.
3/7/17       #8: How to tell if WB has frost damage ...
Eric Member
Definitely not frozen solid, but I think at least one or two gallons were "thickened" until they warmed up. I had hoped there was a sure way of testing, I'm told latex really changes to smelly curds. I'll stick to the original plan of dumping it as it's not worth the risk.
Thanks all
