Subject: Re: sanding
sanding
3/26/17
nicko
Hi
I am just curious as to how many pieces of 150 sandpaper any one would use to sand both sides of a 36 inch raised panel interior door before finish. i am just trying to get an idea how often any one changes there paper.
So it would be sanding all the rails and stiles and all the flats of the raised panels. I am using 5 inch mirka gold.
Thanks.......Nicko
3/26/17       #2: sanding ...
One disc of 150 grit. But I have no idea of what preparation, previous grits, and what diameter you have used. Also no idea what sander and orbit you are using. No idea if you ran it through a wide belt, etc....So for me, one, for you? No idea.
3/26/17       #3: sanding ...
Sorry, re-read that you are using 5". But we still need more info to tell you when to change it.
3/26/17       #4: sanding ...
denny jahnz
I would suggest looking into the surfprep system and their surge sander. This is what I have gone to recently with good results.
3/26/17       #5: sanding ...
nicko
thanks for the reply rich
i am using a mirka ceros five inch sander. the doors are oak raised panel and are already pretty smooth from my local mill. I am just cleaning them up before two coats of conversion varnish. I am using one disc per side. After one side the disc is pretty well spent. It takes me about four or five minutes to random orbit one side of a door.
I would like to find some better paper I use the mirka paper because the hole pattern matches the mirka sander.
Thanks...............Nicko
3/26/17       #6: sanding ...
Does "already pretty smooth" mean they have been rough sanded, or they still have mill marks? If they've never been sanded, I'd start with 120.
3/27/17       #7: sanding ...
JM
Look into the carborundum premier red paper. Im sure there are others as good, but its the best we have come across. Seems to not leave as many swirls in stain grade and the disc lasts a lot longer than the cheaper alternatives.
We use a cheap Mirka paper on MDF, but use the premier red on stain grade stuff.
