Subject: Re: Quieter spray booth exhaust fans?
4/18/17
Matt
We are considering buying a larger spray booth (16' wide open face, 10' height) that will likely have a 5hp fan.
Our current booth is a 9' cube with a 2hp fan, and the noise (constant loud droning) is bad enough to warrant asking around if anyone knows of any quieter fan options available.
Most likely we would be buying a GFS open face, which is what we currently have, and otherwise like.
Roof height is about 14'.
4/18/17       #3: Quieter spray booth exhaust fans? ...
herb johnson
two options
put the fan on the roof, very easy to do
gfs sells a fan made by greenheck that is a lower db, but they charge up for it
frankly get a vfd and turn the speed of the fan down, cheaper and save you money in the winter time
good luck
herb j
4/18/17       #4: Quieter spray booth exhaust fans? ...
Bob Niemeyer  Member
There is lots you can do to tame the "beast".
Ours was a beast and here is what we did and now you can talk a normal voice while it is running.
1. Set the whole booth on a 2" wide rubber strip that is 1/4 thick. You can buy this online. This will isolate the booth from the floor.
2. Buy CLD tiles and place them on all the panels on the outside. Dont use Dynamat , it is not the same. The CLD's will stop the "booming" noise that large sheet metal panels make when they vibrate. Get these from Sound Deadener Showdown
3. Different fan blade, order from Multi WIng America. Call them and give them the specs of the booth and tell them you want the most quiet blade they make for the application.
4. Wrap stack with sound matt from Audimute Sound Products.
5. If local codes allow it a VFD is nice to lower the speeds when "full blast" is not required.
Do all of the above and you will be surprised of the end results. Just make sure you put the CLD tiles on the backside of the exhaust plenum before you set in place(if booth is up against wall)
4/19/17       #5: Quieter spray booth exhaust fans? ...
Bart
Not sure if you can adapt it to your situation but a belt drive explosion proof variable speed fan is much quieter. They can also move just as much air. Direct drive fans are seriously loud. They're great for moving particulate matter you're moving mostly pre-filtered air.
my2cts
4/21/17       #6: Quieter spray booth exhaust fans? ...
Matt
This is just what I was looking for, thanks guys. I will look into each of these.
Our booth actually is a belt driven one, and the belt is a V-link belt (which also makes belt drives quieter) but that really didn't make much difference. I think our fan is just an older, noisier style.
I'm hoping we can locate the fan outside as well, that has been suggested to me by our vendor as well.
Thanks!
4/21/17       #7: Quieter spray booth exhaust fans? ...
Matt
Bob, how many of the CLD tiles would you suggest? Did you guys basically cover the whole surface exterior, or just place a few in the most "floppy" locations, or a certain amount per square yard?
4/21/17       #8: Quieter spray booth exhaust fans? ...
chris
you will need to upgrade make up air too as you will be pulling twice the air. that will increase noise too.
4/21/17       #9: Quieter spray booth exhaust fans? ...
Bob Niemeyer  Member
Matt, we placed 8 CLD tiles in the center mass of each panel. Yes it will cost a few hundred bucks, but well worth it.
