Subject: Re: SW Water White Conversion Varnish VS. Lenmars MegaVar WW CV
4/23/17
Luke Member
I recently switched conversion varnish brands from SherwinWilliams to Lenmars MegaVar...both excellent products. I finish wood products for a window company. With SWCV we thinned it bout 40% after catalyzing, used it for sealer and topcoat.. worked well. With the MegaVar CV its recommend to thined up to10% after catalyzing for sealer and no thinning required for top coat. I I've only been spraying for bout a year . I would like your feedback on comparing the 2 brands, how much you thin it throughout the season. It seemed to me SWCC was very thinned out but it dried faster. MegaVar is recommend to thin 10% for sealer coat nothing for topcoat. Can't spray it on to heavy otherwise sealercoat dry time slows way down. Would thinning speed up dry time? would u beable to apply it heavier whith in in specs with 1hr dry time? What r some thinning recommendations for summertime? Anything else bout comparing the 2 products. SWCV did dry faster when thinned with Xylol but more expensive with the add on. I'd like to stay with MegaVar unless someone can change my mind. Thanks you
Luke
4/23/17       #2: SW Water White Conversion Varnish V ...
Leo G
Of course the SW dries faster, at 40% it's mostly thinner. If you thinned it 10% its drying speed would be slower.
4/24/17       #3: SW Water White Conversion Varnish V ...
Luke Member
Im very new to spraying and catalyzed conversion varnish. The guy who had been hired to setup out spraying department was the one who told me ro thin it so much. I was going off what he said. When spraying CCV why would u thin it so much? I thought thinning was strictly for proper flow for spraying?
4/24/17       #4: SW Water White Conversion Varnish V ...
Leo G
If you are spraying out of a cup gun then you might have to thin it that much. AAA Pump and I wouldn't thin it much more then 10%. At 40% your build will take forever.
4/24/17       #5: SW Water White Conversion Varnish V ...
Luke Member
Def need to thin the conversion varnish for 1st coat sealer just for the fact it drys faster. 40% is crazy! And he wasnt catalyzing b4 thinning it. What kind of problems am i going to run into in high humidty? How do u deal with it? Retarder?
4/28/17       #7: SW Water White Conversion Varnish V ...
Jim Clark
I use Megavar conversion varnish and
thin it 50%. sprays great that way.
I always use their vinyl sealer first,
also thinned 50%.
4/28/17       #8: SW Water White Conversion Varnish V ...
Luke Member
Why are u thinning it so much? Im using a HVLP gun and it seems to run fine without thinning. I thin it 10% when apraying 1st coat as a sealer. Am i missing something when it comes to spraying CV or is it just a personal preference with thinning it so much.
4/30/17       #9: SW Water White Conversion Varnish V ...
Matt
We spray SW WWCV as well, and only thin it 10 to 20% for sealer coat, and it works just fine.
There's no need thinning it 40%.
10% butyl acetate is a good recipe.
