Subject: Re: Matching Dyed Veener--working with Dye stains
4/24/17
Chris
Hello guys. Got a client that wants me to match a Dyed gray veneer from Tabu.
These veneers are super expensive. She wants to see if i can match it or at least come close. I already told her that a 100% or even a 80% match will be nearly impossible. But want to try anyway and see what we come up with.
We will be using white sapele or anigre and from what i know, we will have to bleach the wood first.
Can anyone tell me how and what colors to use to accomplish this color?
Ive searched around and cant seem to find any white or grey dye stains.
What pigmenting is used in dye wood stains?
4/24/17       #2: Matching Dyed Veener--working with ...
Pat
Lockwood has a silver/grey dye. They're powdered and you mix them yourself in water, alcohol or oil.
WD Lockwood
4/24/17       #3: Matching Dyed Veener--working with ...
Shane
FYI... that's a very hard match... we often use that tabu on commercial millwork and I regularly have to match some hardwood edging/nosings that butt up to the tabu veneer....I make a pigmented spray stain with Sherwin Williams sb stain colorants.... We use Anigre for the hardwood and bleach the bajeesus out of it to get all the color out... obviously white tint with a drop of black and a little raw umber... stain is mostly naptha and some acetone so we can spray the stain wet enough that the tails are flashing off right behind the stroke. Tabu looks very blue/gray before it's wetted out or topcoated.. but once it has a finishit looks is grey/brown.
4/25/17       #4: Matching Dyed Veener--working with ...
Chris
Thanks for you response guys.
I will into those dye stains from Lockwood. Thanks Pat.
What about using Mica powder to mix for dye stains?
Has anyone worked with these before?
If yes, how
View higher quality, full size image (519 X 373)
