Subject: Re: Clear over metal
Clear over metal
5/3/17
Kevin Member
I need to clear coat some old corrugated metal for a bar front I'm building. My understanding is acid catalyzed finishes like CV and precat are a no go. What about 2K poly? I guess an auto finish is logical, but would prefer something I can get from my supplier. Any other recommendations?
5/3/17       #2: Clear over metal ...
Rick Mosher
I would make sure the metal is thoroughly clean. (Acetone or MEK should work well for this) Then do an acid etch with phosphoric acid before sealing with the best 2k isolante you can get in your area. I really like Chemcraft's but there are many made.
After the isolante you can apply a 2k urethane in any sheen you like and you're done. I would do adhesion tests on samples first just to be sure.
5/4/17       #3: Clear over metal ...
Kevin Member
Thanks Rick. I have some isolante from chemcraft so I will give it a shot.
