Subject: Re: bleached walnut
bleached walnut
5/6/17
mike j.
I am double bleaching walnut veneers and have found some veneers show small black spots, not much larger than a pin head, randomly spaced. Has anyone else seen this? Does anyone know what they are or what causes these spots. Not all veneers bleached have these spots. The spots are not visible until the veneer is bleached. Thanks.
5/6/17       #2: bleached walnut ...
Probably metal particles from inside your shop and on the veneer. Little bits of steel wool is the likely source.
5/7/17       #3: bleached walnut ...
mike j.
I use no steel wool in the shop. Someone did mention that. I suppose it could be in the veneer as it is laid up on plywood. It doesn't seem to have any mass to it if you know what I mean. Just a black dot. At this point we are planning to test each sheet with a bleached 1" strip on the bottom of the panel to see if any show up, then okay the panel for use. Eighty sheets of plywood are required in the job, a library, along with solid wood. Of course much of the veneer will not be seen as it is tops and bottom of shelving, covered with books, sides and interior parts.
5/10/17       #4: bleached walnut ...
Thomas
good bet the spots are from ferrous "specks" 90% of "blackish" spots & stains are easily removed with a solution of oxalic acid (sold as wood bleach). It's a staple in every experienced furniture refinishers arsenal. It shouldn't cause any additional bleaching where applied. Test sample areas, & good luck.
5/10/17       #5: bleached walnut ...
mike j.
I should've mentioned this was done and the spots did not go away, We did a test on the first ten sheets of plywood. We bleached a 2" strip across the bottom of each sheet. No spots showed up on any sheet. We plan to go ahead with the project, testing each sheet before use. Thanks for your suggestion.
