Subject: Re: minimum temp for applying vinyl sealer
5/10/17
nick
I often use SW's fast dry vinyl seal and the pds has no mention of a minimum temp. for application in either non catalyzed or catalyzed form and hoping someone here would have that information? Thank you in advance.
5/10/17       #2: minimum temp for applying vinyl sea ...
Shane
I'd say your safe in shop conditions 65 degrees F..... That's not always a luxury in smaller shops or low production. My advice would be to keep your material at room temperature as well as your substrate best you can in winter months. Some people suggest heating the room just before spraying. Some folks will suggest a strap heater on your material bucket too .....big differences in temperature between coating and substrate can pose a lot of issues. Problem I see with that is a huge swing in temps as the coating is trying to flash off and cure. All of a sudden cold air is pulling across the substrate after the heat is leaving the room from the cold booth air being pulled across the surface. that being said, years ago I worked in environments that were not so ideal and sprayed at room temps of 55 degrees or less and never had finish failure... it's just not ideal or worth it if money/ reputation is on the line.
5/11/17       #3: minimum temp for applying vinyl sea ...
nick
I talked to my SW rep today and he told me SW recommends 60 degrees and up for "optimum performance"...so
i'll abide by that.
I really was curious if it had a higher temperature need both when spraying and curing when catalyzed as this stuff puts out some formaldehyde when catalyzed telling me some polymerization is taking place and odds are higher temps for a longer period of time may be necessary.
5/13/17       #4: minimum temp for applying vinyl sea ...
Jeff Austin
Applying and curing are two different things. Curing is definitely heat related. Flashing off is also heat related. Ambient temperature is what all coating manufacturers relate to. Which is 77F. Plus or minus 10 (67-87)is about all you can expect your coatings to work best in.
