Subject: Re: conversion varnish over oil
5/23/17
bruno Member
Hi , I m using a SW conversion varnish as a top coat(kenvar LF v84fh72) could it be used over an oil?
thanks
5/23/17       #2: conversion varnish over oil ...
What oil? "Oil" is a pretty broad product description.
5/23/17       #3: conversion varnish over oil ...
bruno Member
Hi Rich
the oil I typically use is the Liberon finishing oil
5/23/17       #4: conversion varnish over oil ...
On on site Liberon is described as' A blend of high quality oils, resins and dryers, Liberon Finishing Oil resists water, heat, alcohol and food acids, making it ideal for kitchens, bathrooms and other high-use areas.
So when it says resins, it is some blend that is more like varnish. Personally, I'm no fan of experimenting with odd combinations of finish. Too easy to get a call back and refinishing job in the future!
5/23/17       #5: conversion varnish over oil ...
bruno Member
Thanks Rich for the quick answer, the project at stake being rather large i will not take a chance .
5/23/17       #6: conversion varnish over oil ...
CraigM
I've done it a fair amount over Watco oil. I usually wait at least 24 hrs before topcoating
5/23/17       #7: conversion varnish over oil ...
CraigM
An appropriate sealer would probably work as well.
5/25/17       #8: conversion varnish over oil ...
I just had this conversation woth my ML rep and he said you don't want to use oil based stains. Stains like Mohawk are an "arcrylic modified" and that will be fine
