Subject: Re: Pump workflow
Pump workflow
5/31/17
Mario Castelo
Bought a plural component machine the other day and i'm seeking advice on how to use it in the most useful way.
I only spray 2k PU, both clear and pigmented.
Currently i have a Wiwa system for clears and use a Wagner Puma 28-40 for the pigmented basecoat and a Kremlin Eos 15-25 for the topcoat...everything is hand mixed (hot potting).
At this time 75% of my work is painted so i will keep my current system for clears my big dilemma is if i should use the plural component machine for the pigmented basecoat only and avoid contaminations which makes sense in a way but in the other hand i would still have to hand mix all the top coat and that feels like i'm not really taking advantage of my plural component system.
5/31/17       #2: Pump workflow ...
chris
i spray 2k urethane but only sealer and topcoat. use a plural system with a pump for catalyst and 2 kremlins for sealer and topcoat.Have a switching valve to alternate.
also have a pump to flush after use to clean.
it should be fairly easy to use system for both.
check with your supplier to see if catalyst needs to use a sealed pump to keep any moisture out.
i am using a graco promix 2K system.
5/31/17       #3: Pump workflow ...
Mario Castelo
Thanks for the tips!
My system unfortunely is nothing like your's. It's a mechanical system, but it does have a flushing pump (Kremlin 10.14) and the catalyst pump it's an enclosed unit (kremlin flowmax).
For switching between base and top coat i would need a 3 way ball valve, that makes a big waste of material comparing with your system because it also needs to flush the pump.
