Subject: Re: airless orientation
airless orientation
6/2/17
sibbs Member
Not real satisfied with my turbine unit's finish with tinted CV I picked up an inexpensive airless Graco Magnum X5 for this next tinted CV job ( I don't do many of these). I was able to get it all sprayed but lost siphon a couple times getting it out of a gallon can and cleanup was rather messy. In other words not a smooth operation and thought it would be nice if I built a rack this mounted to upside down to gravity feed the input using a funnel and tube so I could add CV as needed, put a T valve in to drain the hopper if I was done, and then add solvent to clean. Can this unit be operational if it were upside down? Can any airless unit do this?
6/2/17       #2: airless orientation ...
Nick
I would keep the pump upright. Graco makes a paint hopper that would most likely fit your machine with either no or few modifacations. this should make clean-up and priming easier. Also by the time you've cleaned it up a few more times you'll get it figured out.
