Subject: Re: Bleed through
Bleed through
6/3/17
Pinetree
I was wondering if anyone here has been having a problem lately with bleed through . I've been using Chem craft water base and general finishes water base in light colors like gray or white. We have had three units with this problem one took about 2 1/2 years to start to show through and one only took two months before it showed. The wood we used is popular or soft maple paint grade with mdf. We always contact directly to the manufacture about finishing supplies not to our distributor to get the exact way we should use this product all of them said that we can use the product without a primer it is a self priming product . Now general finishes has come out with the stain blocking primer and they tell you to use it and our camp craft rap has told us now to use a primer also . I am just concerned if we keep using these products with the primers are we still going to have a problem has anyone out there ran into this . Our process was we apply two coats of the finish then Sandown the raised grain with 320 sandpaper then apply to more top coats of finish with sanding between each coat .
6/3/17       #2: Bleed through ...
Bart
It happens to all finishes. I just had a job where I had to go on site after the cherry edgebanding bled through right next to some maple edgebanded cabs. You need to either prime with a stain blocker like zinnser bin shellac or spot prime.with a rattle can. Poplar can be real bad and maple does have those dark spots that will bleed through. I've used GF for over a decade and what I do is keep a rattle can handy after the first undercoat to spot spray after sanding. You may have to do it twice after another undercoat app.
good luck
6/5/17       #3: Bleed through ...
MLC has always had a heavy body stain blocking wb primer. First it was Polystar, now its Agualente.
Poplar and soft maple bleed. Top coats don't stop it alone.
BIN is always a good primer and its available everywhere. Not the best sanding, but it blocks stains better than anything.
6/5/17       #4: Bleed through ...
Pinetree
Everything get primed now with stain blocker. Now all they have to do is teach their people to tell people what you guys just said. Thanks
