Subject: Re: textured clear coat (anti slip but fine grit)
6/7/17
Mitch Bray  Member
Website: SawyerBee.com
I have a new product we've been developing. It is a maple cone with a 3 degree taper that yarn is wound onto. The cone rotates and it's highest speed non-grippy yarns can rise up (like wool). It is currently finished with a semi-gloss lacquer. I would like to test out something with a light texture to introduce some grippiness. I am thinking along the lines of 220 grit sandpaper. Finish needs to be clear. Any advice is appreciated. Thanks - Mitch
http://sawyerbee.com/blog/the-ball-winder-is-alive/
6/7/17       #3: textured clear coat (anti slip but ...
Shane
I've had good results from using "shark Bite" anti slip additive found at your local residential/contractor paint supply stores added to my clear... I made samples of different amount of grams added to my topcoat to get the results needed.... It's basically plastic granules and they are fairly clear once you spray it out. I've had a few job recently and one currently on a very large football stadium project that requires an anti slip clear on some locker seating that I've been using it on mixed in with 2K poly.
6/7/17       #4: textured clear coat (anti slip but ...
Mitch Bray  Member
How do you apply it? Can it be mixed prior to spraying? If so are there any problems with clogging the gun? Do you have to agitate regularly to keep it in suspension?
Thanks.
6/7/17       #5: textured clear coat (anti slip but ...
kevin
i second Shark Bite. its just an additive. u add it to your material and spray away. no problems in my experience.
6/8/17       #6: textured clear coat (anti slip but ...
Bob Niemeyer  Member
ICA Wood Coatings has 3 choices for a textured clear coating. Go to the website
www.icaamerica.biz and call the office and ask about the textured finish. They will get you to the right source.
http://www.icaamerica.biz
6/19/17       #7: textured clear coat (anti slip but ...
Matt
Shark Bite can be applied to wet finish using even a cheap sandblaster gun. I don't know how feasible this is on a high production run, but if you are spraying these by hand already, it's probably not much more to pick up a small beading gun.
You probably could also get similar results just buying the glass beads for sandblasting. That's all Shark Bite really is--- graded bits of silica (or similar). Probably way cheaper to buy a bucket of fine beads, that's probably enough to do many thousands of these cones.
Shark Bite is a good product. We put it on the floor around our tablesaws when we painted the floors. Very safe, non-skid surface, and wheels roll across it well.
6/19/17       #8: textured clear coat (anti slip but ...
Mitch Bray
Thanks for the input. I bought seal krete clear grip. Turned out too aggressive, but knocking it down with a scotchbrite got me where i need to be. I'm not sure if this is a go for final product, but it's a start.
