Subject: Re: Spray stain on Maple
6/10/17
Nick Cook Member
Website: http://www.cedarrivercabinetry.com
I'm having a hard time getting a non blotchy finish on hard maple. I've tried first applying a neutral stain base in water base. Then spray with water base spray stain. I've tried
various wash coats in different ratios of lacquer to thinner. The higher the lacquer content in the wash coat the redder the color gets, which I can deal with adjusting if I can resolve the blotch problem. I'm looking for a straight forward finish process for this job because it's fairly large. Any better methods for finishing maple?
6/11/17       #2: Spray stain on Maple ...
Vince Member
I just worked out an amber color on maple. It ended up with a busy schedule, but looks really good, zero blotchiness.
It is at the end of this thread:
http://www.woodweb.com/cgi-bin/forums/finishing.pl?read=809748
6/11/17       #3: Spray stain on Maple ...
cabinetmaker
ML Campbell clear stain base
red this:
http://www.woodweb.com/knowledge_base/Finishing_Techniques_for_BlotchPron
e_Wood.html
6/15/17       #4: Spray stain on Maple ...
Ryan
I've been round and round with this problem, done washcoat, have done clear stain base, it never looked that good , the best thing I've found is spray no wipe that looked the best, you just have to be consistent in your application, which is a little challenging at first.
6/15/17       #5: Spray stain on Maple ...
Nick Cook Member
Ryan,
Would that be a solvent based spray stain?
6/15/17       #6: Spray stain on Maple ...
Ryan
Yes it is , your using water base right, is solvent a possibility?
6/15/17       #7: Spray stain on Maple ...
Ryan
If you can't do the solvent based you'll have to tone it
6/15/17       #8: Spray stain on Maple ...
Nick Cook Member
Ryan, yes solvent is a possibility.
6/15/17       #9: Spray stain on Maple ...
Ryan
Nick
That is how I do all mine, it seems to be the easier best looking route, it's pretty fast also, If you haven't done it before, just practice a little, and be consistent on your passes, you have some fudge factor, but I just try to make the same amount of passes on each piece, keeping consistency, take any fast drying solvent based stain cut with naphta 25-50% and spray some samples , you might already know this stuff but check out the forums on here about spray stain very helpful.
