Subject: Re: AAA fluid hose diameter
7/4/17
Kevin Member
Wondering what the negatives are to using a 1/8" diameter fluid hose instead of 3/16". They are lighter, hold less paint and less solvent. Anybody noticed a difference? I'm using a 10:14 pump.
7/5/17       #2: AAA fluid hose diameter ...
RobertJ
If Kremlin is your pump, call Kremlin's 1-800 #, they will provide you with the do's and do not's.....personally, would never deviate from what the manufacturer suggests.
7/5/17       #3: AAA fluid hose diameter ...
herb johnson
i would go with either hose, won't make much difference but the smaller hose is more likely to clog due to smaller diameter, also if the material is really thick you will need to increase the pump pressure to get the same delivery, i would also check the price of each, kremlin parts are relatively high, i would make sure the price for both hoses are close to each other
good luck
herb j.
7/5/17       #4: AAA fluid hose diameter ...
cwk
you will find that you will have up the pressure to get the same amount of material on the work. stick with 3/16". the 1/8 will work great if you want to spray stains.
