Subject: Re: Fastest Drying White for Samples
8/2/17
We run a lot of short (3') custom molding profiles for customers. When they are going to be paint grade we try to ship them primed. Looking for a super fast drying white, can be flat like a primer or satin.
We've always used rattle cans for the samples but the dry time to allow sanding and a second coat sucks.
8/2/17       #2: Fastest Drying White for Samples ...
John Member
I like BIN shellac based white primer. You can brush or spray it, it dries quickly, sands great, easy cleanup with ammonia in water or DNA.
John
8/2/17       #3: Fastest Drying White for Samples ...
tyler
Chemcrafts Versaprime has a dry to sand time of 10 minutes. it's by far the fastest i've ever used, it performs really well, hides great, sprays great. A personal favorite.
8/2/17       #4: Fastest Drying White for Samples ...
Mastercabman
I always like white vinyl primer from MLC
8/2/17       #5: Fastest Drying White for Samples ...
Rick Mosher
If you don't have to have super durability I would use Sherwin Williams OPEX Lacquer Primer Surfacer P61W1
Builds and dries very fast and can be used as a primer and finish.
8/7/17       #6: Fastest Drying White for Samples ...
Matt
I second the BIN white shellac. You can even brush it on if needed.
It's alcohol based so it should cure pretty quickly.
