Subject: Re: wooden door in shower
8/20/17
Ed
I have a customer that has a wood door in shower leading to sauna. Any ideas for the best finish?
8/21/17       #2: wooden door in shower ...
Tyler
I would only do this if they considered using Teak with tung oil. Supply a treatment schedule to them where they pay you to come out every 6 months or so and treat the door, oil it, touch it up, etc.
8/21/17       #3: wooden door in shower ...
RobertJ
Epoxy. Or, Awlgrip Awlwood MA. Used in the boating industry. Gloss finish. Epoxy top and bottom of door.
8/21/17       #4: wooden door in shower ...
Some kind of finish that isn't effected by lime and soap scum remover, and will be so flexible it will move with multiple daily expansion and contractions for high heat and humidity. I don't think any exist that will last very long. Don't give them a warranty if they insist on that door!
8/22/17       #5: wooden door in shower ...
I would give it a minimum of three coats of this West System hardener with their regular 105 resin. I would do a couple of spot epoxy coats on any end grain before doing the whole door.
This is used specifically for clear coating hulls of full wooden boats. That's it. No varnish only uv protected epoxy.
In your case the clear aspect is a better choice regular epoxy is amber. It solves all of your problems.
DO NOT THIN THE FIRST COAT OF EPOXY.
The teak thing is overkill. You will be fully encapsulating the wood. The door will not rot. Personally I think a Sapele door with 4 coats of epoxy would be nice. I would do it in my own house if I ever have the time.
West System Special Clear Hardner
8/23/17       #6: wooden door in shower ...
Wood in the shower is the same as wood outside: Once you finish it, you have a job for life.
Teak, no finish.
8/25/17       #7: wooden door in shower ...
Lee Masters  Member
I agree and also recommend using teak wood! It's the best option to deal with that environment.
8/29/17       #8: wooden door in shower ...
Wooderra Makris
Website: https://www.wooderra.com
I agree wholeheartedly. Teak is the best option for bathroom application and it doesn't require any finish. I am very much interested in this eco-friendly product so I can actually back you guys up with the benefits of Teak being used in the bathroom. Any homeowner who takes pride in the presentation of their home will profit from the application of teak accessories, such as teak door, teak flooring, teak bath mat, teak bench, and so on.
They are structurally sound, visually appealing, and practical because of their resilience and durability. Teak's noble properties make it a long-lasting product that will perform with proper maintenance, making teak bathroom products an economical option.
Teak bath products are also recommended for commercial use, because, same as with the residential applications, they complement the overall ambiance of an area, businesses. Teak bath products are the ideal choice for spas, public shower facilities, and swimming pool areas.
What makes Teak stand out is actually its water resistance thanks to the natural oils present in mature teak hard wood. The mechanism of natural teak oil works to fill all the micro tubes and prevents humidity from penetrating the grain and altering the cellular structure. For this reason, teak flooring is the least likely to be prone to contraction and expansion.
Additionally, the oil content acts as a safeguard for teak door, teak flooring or any other teak usages, protecting it from fungi, bacteria, and termite attacks, which are primary enemies to other hardwood species. Furthermore, teak’s strength is owed to its silicon content that prevents oxidation from contact with metals over a substantial length of time. This is why teak has been acclaimed as a durable choice for home applications, which can last for hundreds of years with proper maintenance.
It is super easy to care for solid teak accessories. To maintain its great form, it may be also advisable to use oil on teak accessories depending on how it is finished or not finished. With proper care, you can retain its natural sheen which beforehand will require a clean and dry status of the subject as a prep step for oil treatment and a specific cleaner for teak products is also needed. The number of oil coats should depend on how rich and thorough the finishing you wish for your solid teak accessories.
View higher quality, full size image (1000 X 600)
8/29/17       #9: wooden door in shower ...
Bart
A little OT. But is that a dope plant outside the window? Not that I've ever seen one before. Just in magazines. :-)
