Subject: Re: Exterior Door Stain
Exterior Door Stain
10/3/17
John Member
What brand/type of stains are you all using for an exterior front door? I've never had to stain/clearcoat an exterior door - until now, so I'm interested in your experience and recommendations. If it matters, the wood is probably going to be rift sawn white oak for the frame with plain sawn panels. And my preference is a waterborne topcoat, something like Target Coating EM9300. Thanks.
John
10/3/17       #2: Exterior Door Stain ...
I am no fan of clear film coatings on exterior doors. Just ask any wood boat guy, it takes a ton of maintenance. Likely to be sanded and refinished every 3 to 5 years based on locale and sun exposure. I'd wager, you will be the first person they call when the film starts to crack and let moisture get under it. Personally, they couldn't pay me enough to do that job.
10/3/17       #3: Exterior Door Stain ...
John Member
This door is behind a storm door on a covered porch. It gets direct sun for a couple of hours some days on the bottom third. The existing flat veneered wood door was last refinished by an amateur using BORG stain/varnish about 15 years ago and shows only minor degradation where the sun hits it.
John
10/4/17       #4: Exterior Door Stain ...
Leo G
I've used the EM9300 on an exterior door and it performed very well. You need to put it on thin and many coats. It calls for 2-3 wet mils or it'll go blue on you. The door I did I put on 5 coats. As for stain, you probably want something with a metallic pigment, stable and reflects UV
10/4/17       #5: Exterior Door Stain ...
RobertJ
A word of caution. A Wooden door behind a Storm door( I assume a full view glass door) is not a perfect scenario for keeping the door from feeling the effects of heat during the summer months. Tell your client to remove the Storm door.
10/4/17       #6: Exterior Door Stain ...
John Member
Thanks Robert. I'm aware of problems that occur with a storm door over a wood door. In this case, the storm door was installed 8 - 10 years ago. The finish was last redone about 15 years ago with low end products and still looks pretty good other than the degradation (oxidation) where the sun hits it directly. The door is still flat, with no evidence of the veneer splitting or cracking. I think the new door will be OK with higher end finishing products. If I'm wrong we can always remove the storm door.
John
10/5/17       #7: Exterior Door Stain ...
Jonathan Mahnken
General finishes has a complete water based exterior stain/clear coat system for this. I did a mahogany entry that is east facing with an overhanging porch and its still looking good five years later.
10/5/17       #8: Exterior Door Stain ...
John Member
Thanks Leo. That gives me some confidence the EM9300 will stand up well.
John
10/5/17       #9: Exterior Door Stain ...
John Member
Thanks Jonathan. From what I saw in their literature, GF's line of exterior stains is pretty limited, although I'm sure I could custom blend them to extend the range. Normally, I use mostly GF products, and I might this time as well, but I'm looking to see what other systems people are using and how they have performed.
John
10/5/17       #10: Exterior Door Stain ...
Jonathan Mahnken
You can call them and or send a sample and they can make a custom color in their exterior formula
11/3/17       #11: Exterior Door Stain ...
John Member
What a disaster the EM-9300 was. Bubbles large and small, even when I dripped some off the stirrer onto a clean piece of glass and spread it out with a razor blade. And it bridged around the pores in the sealed white oak and looked terrible whether I sprayed light, medium, or heavy coats. Lots of correspondence with Jeff Weiss at Target Coatings, who was very nice and very helpful. He refunded my purchase and replaced the product, which was very generous (except it can't cover the lost time and rework), but I asked for EM-6000 instead. I doubt I'll ever give EM-9300 another look. I ordered some GF Exterior 450 and just sprayed the first coat today. What a difference. Flat, smooth, no issues at all.
The EM-6000 arrived today and I sent the remainder of the EM-9300 back so they can hopefully find out what was wrong with it.
John
11/15/17       #12: Exterior Door Stain ...
Ed Arthur Member
Website: http://doorsbyinvision.com
The main thing to consider when doing an exterior stain is not to us dye stain that will fade easily. I’ve never heard of metallic based pigment. I use linear polyurethane on the doors I refinish and it works great.
