Subject: Re: Automatic stirrers, for small quantities (1 gal or under)?
10/4/17
Matt
Is anyone aware of any small size pneumatic automatic stirring devices? I see them frequently for 5 gallon size cans but we would like something smaller that is more easily used on smaller quantities, such as 1/2 gallon or 1 gallon.
Most of our finishes are not prone to settling out, but the clearcoat is, and it sometimes sits for an hour or more between uses. Just too easy for even the best of us to forget to go swizzle it around before shooting it.
10/4/17       #2: Automatic stirrers, for small quant ...
herb johnson
just buy a one gallon air shaker, dedoes makes one there are also offshore mfg ones for sale on line
be sure to make sure the lid is tight lol
the also shake pint qt and pps cups
good luck
herb j
10/4/17       #3: Automatic stirrers, for small quant ...
Matt
Sorry Herb, I wasn't too clear with what we needed. Thanks for the suggestion.
I'm referring to an agitator for finish that's actively being sprayed, keeps the flatting agent in suspension.
Thankfully we do have a shaker that adapts to 5g and 1g cans for shaking before we catalyze it.
10/4/17       #4: Automatic stirrers, for small quant ...
pdub
We made on that works for any size container.
Got a cheapo Home Depot pneumatic drill and a squirrel cage agitator on a hex shaft. We mounted the drill onto a board (with U-bolts) then attached that to a fixed board attached to the wall with slots and hand-nuts so that the drill and attached board can slide up and down and be tightened in place. The drill is connected to an adjustable air regulator.
Slide the drill up, put your container underneath and then slide it down as deep as you want it. turn the regulator on (barely) and your stirrin' baby.
10/5/17       #5: Automatic stirrers, for small quant ...
Mike Fuson
Pdub that sounds pretty brilliant. Got me to thinking about an electric stand mixer like you use in the kitchen? Is that a crazy idea Matt??? Now only spins but it revolves too, plus it’s variable speed, or at least mine is.
10/6/17       #6: Automatic stirrers, for small quant ...
Matt
Pdub, that sounds interesting and reasonably easy to set up.
I actually found a pneumatic magnetic stirrer on Amazon for $100 that I'm going to try. Might not be strong enough to "mix" the paint, but I bet it will be plenty enough to keep the fluid rotating and not settled out.
I really like the idea of using an air regulator to control the speed. It should "putt putt putt" at a low speed just fine to keep stuff in suspension
Mike, I'm sure an electric mixer would work fine but I will not use an electrical device like that in my spray booth.... at least not that close to fumes.
10/9/17       #7: Automatic stirrers, for small quant ...
DannyB
For gravity stuff, sata makes an (overpriced) agitator cup.
If you are using pressure, Binks and others make 2 quart agitators pot.
