Subject: Re: Spray Booth Heaters
Spray Booth Heaters
11/9/17
scott
We have a 16 x 20 spray booth in so. cal and during our short winter season I'm looking to heat our booth for drying purposes after spraying is completed. Has anyone used infrared heaters mounted on the side walls. We have used a portable automotive unit that has worked but i'm more interested in something permanent and that doesn't have to be moved and stored when not in use. Any suggestions?? Also any idea of daily cost to size used. Thank You for all input.
11/9/17       #3: Spray Booth Heaters ...
Bob Niemeyer  Member
Scott, you have somebody real close, call Prime Heat Systems in ElCajon. CA( just east of SanDiego)Nice systems that work on most coatings. Call them, you will learn alot!!
http://primeheat.biz
11/13/17       #4: Spray Booth Heaters ...
Dan/drbwoodworks
We use a modine hot dawg propane or it can be natural gas unit
11/14/17       #5: Spray Booth Heaters ...
JM
https://www.richelieu.com/ca/en/category/tools-and-shop-supplies/drying-systems/10
55306?sort=&nbPerPage=48
11/15/17       #6: Spray Booth Heaters ...
Matt
We've found it beneficial (in a similar, hot southeast environment) to make sure our make-up air is coming from the building's ridge vents, which pulls the naturally heated air near our cieling back down toward the spray booth. All the heat from solar energy, vacuum pumps, machinery, etc drifts up to the ridge vents, and then back down in the normal air flow.
We are fortunate that our ridge vents are sufficient to match our spray booth CFM. Makes a huge difference. If we open a garage door, shop temp suddenly starts dropping quickly.
Depending on your local laws, you can probably also have a natural gas furnace (located away from flammable fumes) ducted over to your paint area. Natural gas is (in my area) by far the most economical way to heat.
It's not cheap up front, but not really that much more than buying electrical devices, and I consider it far safer. Plus you don't have to hike around propane tanks.
11/17/17       #7: Spray Booth Heaters ...
Modine Hot Dawg's are great. I used to heat my small shop with one of those.
11/18/17       #8: Spray Booth Heaters ...
Dan/drbwoodworks
The Modine hot dawg we use in the spray area draws its combustion air from the outside. The rest of the shop is heated with forced hot air . Our spray area is upstairs separate from the shop .
