Subject: Re: Building A Spray Booth
11/21/17
Daniel Member
I am in the middle of building out a standalone garage to move my shop in to. To meet the need of a spray booth I have been planning to build a 12'x10' room off the back end for a booth. The more research I do the more intimidated I am. Yes, code is in question but not a huge concern, hoping the city will never catch wind. I want to be as safe as possible but my current setup is to open the bay door and turn fans on and have not had any issues yet. With that said, my current plan is to purchase a tubeaxial fan with around 8000 cfms and mount to the wall. Do you have to use duct work and send it out the wall or can you simply go straight out? I would prefer to build up an exhaust chamber to filter out but the cost is now rising. There will be a vent for airflow on the opposite side of the room. How necessary is the exhaust chamber with filters? What material must the walls be? My plan is for simple OSB on the cheap end. I have read several of the posts on here concerning this topic but it just doesn't seem to equate to what I am trying to pull off. My typical week of spray would consist of a couple of barn doors or a few tables with precat lacquer. I am fine with changing up to waterbased if needed.
11/21/17       #3: Building A Spray Booth ...
herb
a little tough love
do not build a booth out of flammable material,
you are putting yourself in jeopardy
in the back of your mind, you already know the city will catch you
any booth that you will see has exhaust filters and a fan, the filters are sized to the open front area of the booth, ten high ten wide 10 k cfm
i really understand what it takes for a small business to operate,i am not some mega factory but i strongly suggest you to water but water still has volatiles in it and the cleaning curve from solvent to water can be steep.
i would hold off on building a booth out of metal with no exhaust filters
national code says to extend the top of the exhaust six feet above where it cross's the roof line i would use at least a twenty gauge material
again, just my two cents
good luck herb j.
11/21/17       #4: Building A Spray Booth ...
Michael Greco  Member
Website: http://www.michaelgrecocabinetmaker.com/
I'll offer, that being a professional forum, anyone posting here has installed and/or operates an engineered booth, installed to code, inspected annually, fully insured.
Since we have invested the money, time and effort to do so, we would encourage you to do the same.
11/22/17       #5: Building A Spray Booth ...
I'll just suggest that 8000 cfm for 120 sq ft is a TON!
11/22/17       #6: Building A Spray Booth ...
Bart
Well since you're bootlegging it you still might as well be safe until you get caught. I would definitely stay away from the flammable walls (fire retardant drywall is cheap). Limit your outlets (better, don't have any in the spray room) in the room and make them explosion proof. As well as all your lighting should be explosion proof. I'd also stay away from the tubeaxial fan. Those things are loud! I would use a belt drive with an explosion proof motor and adjustable speed. A 30in fan can move over 7000cfm. More than enough. I don't think I'd go with an exhaust chamber either. Unless you're going to be using it as a sanding/routing station as well. You won't be moving much particulate matter. A wall of filters will do the job. Since it's your property I'd just put a louverd/shutter cover over my exhaust fan and call it a day.
my2cts
http://www.globalindustrial.com/g/hvac/exhaust-fans/exhaust-and-supply/b
elt-drive-exhaust-fans-shutters
11/22/17       #7: Building A Spray Booth ...
Daniel Member
Bart,
Thank you for that great advice. I don't want to fully commit to it but want to be as safe as possible. I hate admitting that I currently open the bay door and turn a few fans on but it works for now. I would love to have the cash on deck for a legitimate option. Fireproof sheetrock, few as possible outlets, and fan advice will be used.
11/22/17       #8: Building A Spray Booth ...
mc
i just made 1 & it works better than i ever thought it possibly wood. i used 2" metal freezer panels that lock together . i made bi-fold filtered doors & back filter wall. it is 16x24x10' tall. used the freezer panels walls & ceilings. used the correct lighting & venting like is used in a factory built booth . used an inverter so that we can run at lower speed while spraying & when finished spraying we can turn up fan & it helps it dryer better. bought 90% of it on ebay. example - 34" dayton fan & 5hp motor that was dented reg. $1700 for $250. if u shop u can really save & still do it right. good luck.
11/23/17       #9: Building A Spray Booth ...
CraigM
You can use the NFPA 33 standards as a guideline to be safe, but I highly recommend you do things by the book and get signed off from the start. I am currently setting up a new shop for the second time in 10 years. Yes, the red tape is a hassle, but I can sleep at night knowing I won't be shut down. I am a spray shop exclusively though, so I need to be above board. It's a much bigger headache to try and bring a shop up to code later down the line instead of doing things properly from the beginning.
That being said, in many jurisdictions if you spray exclusively waterbased you negate the need for a lot of the paperwork.
12/6/17       #10: Building A Spray Booth ...
Dan/drbwoodworks
Check out JC metal fabrication inc . When I built my building I was thinking like you until we were not getting the finish we were looking for . We did a proper set up and things came out much better and safer . Especially for the amount of lacquer we spray a month .
12/7/17       #11: Building A Spray Booth ...
Daniel Member
Thanks for all the responses. I have recently started building the addition to the garage so we will see how this goes.
12/27/17       #12: Building A Spray Booth ...
seidoww Member
Dude, just set the money you were going to put into the material to build a non certified booth to the side and find a used professionally made and certified booth at an auction site or off craigslist. You can get them for CHEAP.
