Subject: Re: Dye Concentrate
Dye Concentrate
12/11/17
Luke Member
Hello y'all.
I'm looking to speed up wood finishing production at a Window and Door company. Im just curious and concerned that i have my research right wirh dye concentrate. Im trying out a few didferent brands, Gemini coatings and the Mohawk Dye concentrate. It is a mettalized dye that can be used in some solvent and water based finishes. How do u know it's compatible with those finishes? I always do my research before using anything but wouldnt my some confirmation from you all. Right now I'm using Lenmars Vinyl sealer and CV but im looking to change to 2k poly water base or anything else to get away from that nasty formaldehyde. I know I can add it and seal it with Zinnser shellac. Any advise on these dyes and what to look for in water and solvent base finishes that make it compatible would be appreciated. Also what equipment settings to use to spray the dyes. Right now we dont spray any stain. Im using a AAA Merkur for clears and just purchased a SATA HVLP to start spraying stains, toners. Thanks
12/12/17       #2: Dye Concentrate ...
Bob Niemeyer  Member
For windows you need to stay away from metal based dyes. Yes they are more lightfast but still are not made for basically exterior exposure. You need to use Microlith based colorants. Very good color hold out.
ICA waterbased CNA colorant line is a good choice.
They also have waterbased finishes for that exact application. ICA sells to many window manufacturers and has the products you need.
Call the main office for the right Dist in your area.
ICA Home page
