Subject: Re: Touch up sprayers
Touch up sprayers
1/28/18
Chris Member
Do any of you use a air brush gun for small touch up on Cabinets out on the job site on painted lacquer. Was thinking about buying one for this purpose.
1/28/18       #2: Touch up sprayers ...
nick
I don't use a airbrush for on-site spray touch-ups but I do use a Sata mini touch-up gravity gun and have had great results with it...I just dial back the material volume and use the round pattern, I can get near invisible touch-ups on satin and lower sheens, sometimes (oftentimes to be honest) a delicate touch 0000rub is needed for higher sheens touch-ups to be less visible. On the down side it does take bringing along a compressor capable of 4-5cfm, on the plus side if you end up needing to finish a full end panel, door or drawer front it can do the job.
1/30/18       #3: Touch up sprayers ...
JoeW Member
I use an Iwata Air brush regularly for touch ups. It works great. The secret to a good finish is becoming proficient with the brush and it's Technics. Practice.
