Subject: Re: Spraying ICA with gravity gun
2/13/18
Dan
Going to give ICA waterborne a try. And wow is it thick. Any tips spraying it?Thinning? Pressure? With a gravity hvlp cup gun.
I don’t want to put it through my AAA.
2/13/18       #2: Spraying ICA with gravity gun ...
Roy Cameron
Hi Dan
I've sprayed it. The primer is super thick, there is an additive to put in it that thins it. I forget what its called. Ask your rep, they should be able to help you.
2/13/18       #3: Spraying ICA with gravity gun ...
Jim Clark  Member
Website: http://s51.photobucket.com/albums/f386/jcquack/Fur...
A larger tip for your gun can really help.
I have one that's a 2.2 mm. for my
DeVilbiss for thick auto primers.
Usually a 1.4 thru 1.6 is fine for most
but the thicker stuff needs bigger.
2/13/18       #4: Spraying ICA with gravity gun ...
Dan
Thanks guys.
Yeah they are sending some additive to thin. Guess I'll play with it til it works. And yes I will be using a 2.2 tip
2/14/18       #5: Spraying ICA with gravity gun ...
Dan Cook
How is this product for priming for those of you that have used it. We have been using Chemcraft aquaprime water base primer and while it works good it gums up everything. Looking for alternatives.
2/14/18       #6: Spraying ICA with gravity gun ...
Roy Cameron
hi Dan
I believe the additive I used to thin was d1019. I beleive you only use about 1% d1019 by weight along with 1% water by weight.
2/14/18       #7: Spraying ICA with gravity gun ...
Bob Niemeyer  Member
Dan, what product are you going to try? All of ICA waterbased products will seem thick and will require some thinning but your tip should not be a 2.2mm. Use a 1.8 and you will be fine. Remember there is a difference between viscosity and rheology. ICA products atomize very nicely so dont let the viscosity fool you.
Also some dist reps dont know the product very well, if you need advice go to the ICA website contacts area and call one of the technical people listed.
ICA North Amreica
2/15/18       #8: Spraying ICA with gravity gun ...
dar
question for bob, bob I know you are very knowable on ICA products, I use their lp157 exterior, but I am doing a heavy use commercial walnut bar top which product would you suggest, polyester sealer? or not
thank you dave
2/15/18       #9: Spraying ICA with gravity gun ...
Bob Niemeyer  Member
I have finished several high use bars. The key is getting sealed up real good. Also watch out for the parts that hang over the glass washing machines on the backside of the bar.
Use the right Isolante first and from there I like to use Acrylics,the reason why is they are more flexible,dont mind some moisture and the sheens hold up real nice.
Polyester is a good choice for bars that tend not to be in a very wet environment. I still topcoat the PE with a PU. Just make sure to Isolante and also several coats of sealer on the underside if you can.
2/16/18       #10: Spraying ICA with gravity gun ...
dar
bob are acrylics going to be durable enough?
do you have any product numbers for iso and topcoats thanks dave
2/16/18       #11: Spraying ICA with gravity gun ...
RobertJ
Spraying ICA waterborne: I use an older CAT Jaguar with a 1.4 orifice. Spray's fine for me.....
At one time, Devilbiss and ICA teamed up to produce a waterborne gun....don't know the model number, but could be the CVI.
Your distributor may have one, but if memory serves me correctly, it was not cheap, around $600.00
2/16/18       #12: Spraying ICA with gravity gun ...
Bob Niemeyer  Member
For an Iso there is IS203, FAC241 for sealer and OAC series for topcoats. Yes it will be durable enough. The key is put enough finish on for the wear and tear it will get.
If you needed to discuss an SOP for your system feel free to contact me as each application is different.
RobertJ, I have one of those guns and it is very nice. The key to a waterbased gravity feed guns is the inside diameter of where the cup attaches to the gun is much larger.
2/18/18       #13: Spraying ICA with gravity gun ...
RobertJ
Bob N. is correct about the orifice size at which the cup attaches to the gun. The Jaguar gun I have is very large, whereas my Binks and Asturo guns are much smaller.
I have always been pleased with the Jaguar gun....parts are compatible with Binks too!
