Subject: Re: Plastic pails in gallon pot
4/1/18
Heres one that threw me for a loop and pretty much got me completely p.o.'ed and stumped for a bit.
Getting a bit of finish in plastic gallon containers and thought what better than to save them and use them in the pressure pot. Easy to clean. Dont get nasty with WB finishes, and so on. Tossed a gallon of gun and line cleaner in the pot and ran half of it through and let it soak a day. Back to flush and had a nightmare with what seemed like trash or something in the fluid line. Would flow great and then progressively decrease and stop to a dribble. Kept thinking something must have broken loose or gotten in the fluid line and was running up and jamming at a fitting or something. Kept blowing air in reverse direction, try again, disassemble more, try again, over an over until I had disassembled everything. Put a fresh gallon in all fine, then started to happen again. I knew everything was clean as new until it dawned on me. The bottom of the plastic gallon container had bowed/bulged up slightly and was domed a bit. When the gallon was full it would pickup material fine, as the gallon emptied, the bottom of the plastic can was lifting against the pickup tube and getting suctioned on tight.
I took a die grinder with a super fine wheel and ground three very shallow lobes in the tip of the pickup tube. We dont run a filter on the bottom of the pickup tube and have always liked that it will run a gallon down to about nothing in the pail. It never dawned on me how close that pickup tube was to the bottom of the gallon can.
Copious quantities of colorful language didnt make any difference.
