Subject: Re: Black filler
Black filler
4/24/18
Stefano
I'm staining maple with aniline day and I wonder if someone know if there is a black filler for this use
Thank you
Stefano
4/24/18       #2: Black filler ...
Jared Emery
Grab some water-based wood filler from your local big box store and mix some lamp black colorant into it. I think the max is somewhere around 15% by volume. It should be pretty dark. Quick and cheap.
5/1/18       #3: Black filler ...
Stefano
Thank you for the suggestion
Stefano
5/1/18       #4: Black filler ...
Shane
Mohawk epoxy putty comes in black... although it ends up being a little on the really dark gray side.... I would generally go to the epoxy side if it's bigger than an 18g nail hole your working with.... otherwise I've really been loving working with Timbermate water based putties lately... they dry and sand great and can be tinted with universal colors as well...
6/22/18       #5: Black filler ...
Dustin Member
Website: http://www.rhodeshardwoodflooring.com
Woodwise makes a black wood filler. This is my preferred filler when using black. Hope this helps.
