Subject: Re: Staining
Staining
5/1/18
Ron
Website: Truemills.squarespace.com
I'm staining reclaimed oak. It was all sawn from 12x12 timbers, and I've never seen what just happened. I had some 16 in wide jamb, so glued two kiln dried 8 in pieces together. Ran the jamb through the sander with 100 grit and skip sanded them. When I started staining, half of the jamb took the stain well. The other half stayed very light with the strain barely penetrating. Any ideas? Fixes?
5/2/18       #2: Staining ...
Kevin
Sounds like sap... If its an eyesore, tone it to match the rest of the piece. But, usually in keeping with the theme of things, clients use reclaimed wood because they want the rustic appearance and inconsistency. Perhaps making the piece too even is going to take away from that effect.
5/19/18       #3: Staining ...
Dustin Member
Website: http://rhodeshardwoodflooring.com
You might consider tinting some dewaxed shellac and applying a coating over the stain to help even out the color. I prefer the trantint brand of dyes. It's available in a lot of colors and one will likely be very close to the stain color you used.
