Subject: Re: shop carts
shop carts
5/27/18
nick
I'm looking for a vendor for sturdy yet simple carts for rolling 2"× 30"×6' to 2"×30"×10' solid white oak tables (these things gotta weigh somewhere between 100-200lbs) in and out of the booth and around the shop...any suggestions?
5/29/18       #2: shop carts ...
Shane
Harbor freight furniture dollies... some birch ply scrap and a little bit of imagination should make a quick cheap solution/ turn around to get parts mobile for you....
5/29/18       #3: shop carts ...
bill stanisci Member
Lineberry Carts come up at auction. They are always good to have around the shop. They could be modified slightly to meet your needs. I assume you want the table top at a sprayable height?
5/29/18       #4: shop carts ...
nick
I was thinking of just getting a couple of carts for the moving part and spray on horses in the booth as I can fit (5) 30"× 6' tables in my booth. It would be nice to have 10 carts as that would double my production rate but the carts I saw online that looked like they would work were around $100.00 each and the thought of having $1K worth of carts taking up space in my already crowded 1,500 sq.ft. shop is not working for me at least not now.
I will give Shane's suggestion some thought too.
Thank for the replies.
5/30/18       #5: shop carts ...
Puzzleman Member
I would not use the furniture movers as the wheels are too small to move easily. I couldn't find what I need or even close, so I wound up making my own. Used 4" wheels and they move easily. Best decision I made as I was able to make them exactly like I wanted them.
5/30/18       #6: shop carts ...
nick Member
Puzzleman, I'm getting the idea you and Shane are right,,,I'll be building what I need. Thank you for the response.
5/31/18       #7: shop carts ...
Shane
we probably have4 hundreds of the old lineburry type carts throughout the plant... we've obviously snagged them up here and there at closing auctions and such the last 40 years the shop has been in business.... They are great for holding big things and built up jigging for all kinds of shapes/sizes... that being said they aren't easy to come by and are expensive if you do find them.. we have over 150,000 square foot shop and the harbor freight dollies can be had cheaper than buying the wheels themselves!.... heck we even build big ply boxes 30"x60" out of scrap and screw 4 dollies on the bottom to roll around big stuff..... sure some rough shop floors may give you some grief here and there but they are cheap and available.... use your imagination and resourcefulness and they can be a good tool to have around for not much scratch... we must have 500 of them around the shop at all times....
6/5/18       #8: shop carts ...
Gary Member
Make your own simple and cheap
6/13/18       #9: shop carts ...
Jim
1 sheet of 3/4" osb. Cnc router with confirmats. The confirmats did bite well which I was suprised.
