Subject: Re: Bleaching maple
Bleaching maple
6/6/18
Pete D
I found a few different manufacturers for the two part bleach, some use potassium hydroxide and others use sodium hydroxide for part A with hydrogen peroxide for part B.
Any pros and cons or recommended products?
6/7/18       #2: Bleaching maple ...
CraigM
I use the wood kote two part bleach. It works well and is self neutralizing. I've used it on occasional jobs over the last 10 years and never had any issues. I had one job where they wanted walnut bleached white (not sure why) and I had to use two applications, but usually one application does the trick for what I need.
Wood Kote bleach pdf
6/7/18       #3: Bleaching maple ...
Pete D
Craig,
Did you try different application methods like brushing vs rolling vs spraying? The spec sheet you attached mentioned all three options. I'll do some test pieces, but I was curious if, I'm your experience, one method was more consistent or maybe it doesn't matter.
6/7/18       #4: Bleaching maple ...
CraigM
Hi Pete, I usually brush it or rag it on like a wiping stain, have never sprayed it. It didn't seem to make a difference with consistency, I apply it liberally and leave it fairly wet
6/7/18       #5: Bleaching maple ...
Pete D
Cool, thanks!
6/15/18       #6: Bleaching maple ...
Dustin Member
Website: http://www.rhodeshardwoodflooring.com
I'd recommend the one with sodium hydroxide. You can make this yourself by getting sodium hydroxide powder (amazon) and swimming pool grade hydrogen peroxide (27%). A sealer that works well for whitening maple is a product called Bona Nordic sealer. It's for floors but would work for other stuff. It has a subtle white in it and you can use multiple coats. Might be easier than bleaching. Just a suggestion.
7/9/18       #7: Bleaching maple ...
mauricio poli Member
Well, in my opinion these methods are quite dangerous. Anyway we will create native oxygen, which in closed rooms could explode. The gas leaving the wood will bleach our hair and skin.
We need to wait water to evaporate. Wood will move.
Maybe it will be easier and cheaper to buy another lighter wood.
