Subject: Re: refinishing post cat. wood top
6/6/18
stephen Member
how to refinish a wood top on site.
can not spray it
6/6/18       #2: refinishing post cat. wood top ...
scott
We have used MinWax Polycrlic, its brushable and drys very clear, sand 220, another coat , than 320 and another coat.
Also for a more natural look we have used Waterlox Original Finish, is brushable but needs 24 hours between coats, sand and recoat to about 4 coats. Beautiful finish.
6/6/18       #3: refinishing post cat. wood top ...
stephen Member
there were no bonding issues?
6/6/18       #4: refinishing post cat. wood top ...
nick Member
I have never used a WB clear that brushes as good as Targets Em-Tech 2000...the stuff is amazing. With care, good technique, a fine brush and 2 hours dry time between coats a brush stroke free coat is almost attainable. If i remember right it has less than 30 grams of VOC per liter.
Another approach would be to use a solvent base polyurethane. I believe as a general rule they are more durable than single component WB poly/acrylics and they brush out very well...down side 1 coat a day and most have a heavy load of VOC's
