Subject: Re: removing mineral oil
6/7/18
nick Member
Yesterday I had a homeowner come into my shop with a 4'x7'x2" live edge walnut slab that he uses for his dining room table. The problem is he "finished" it with mineral oil (butcher block oil) after placing 1 glass of beer on it he realized this was a wholly inadequate finish. I've sanded the top until I get is wood dust but of course I can't do that with the live edge...any answers out there? Thank you.
6/7/18       #2: removing mineral oil ...
Bob Niemeyer  Member
One thing that works fairly well is scrub the edge with acetone. Do this several times a day over several days. This will draw out lots of the oil.
The other thing to do is suggest removing the live edge, that "look" is going out. It is a little outdated.
Give the table an updated look!
6/8/18       #3: removing mineral oil ...
nick Member
Thank you for the reply, I'll give the acetone wash a go.
6/8/18       #4: removing mineral oil ...
nick Member
PS; I'm just a humble craftsman who hopefully will make this table able to withstand the effects of a cold glass of beer sitting upon it, I leave the esthetics of design to the designers and owners of the pieces I get to work on...it's architects I can"t abide!...just kidding.
6/8/18       #5: removing mineral oil ...
TimG
The acetone wash followed by a couple coats of dewaxed shellac to lock what remains in, then finish as usual.
6/16/18       #6: removing mineral oil ...
Wayne Weber Member
Acetone is not a real good choice to dissolve oil. You are better off with deodorized mineral spirits followed by a thorough dry then DEWAXED shellac.
6/19/18       #7: removing mineral oil ...
nick Member
I just finished the table/slab and so far it's all good...on Friday morning I ragged on paint thinner then wiped off 3-4 times. Then let the wood dry for 6 hours, then used the acetone rag on rag off a couple of times. On Monday I hand sanded lightly with a fine sponge on the live edge...the edge dusted up pretty good. then used a chip brush to apply a 1lb cut of dewaxed shellac to seal the edge.
Today I sprayed 3 coats of CV on top, bottom & edges without a problem.
Thank you for the help!
