Subject: Re: polishing CV
polishing CV
6/25/18
Brad
Working on a mahogany table top.Two coats of SW water white conversion varnish for protection ( dull rub). Anyway to polish this up?
6/25/18       #2: polishing CV ...
JM
May be a stupid question as I know plans change and customers change things, but if you wanted a polished finish, why use a dull sheen to start with.
Now that you are where you are, sand it back a bit, shoot a coat or two of gloss on, then cut and polish if you need it with more sheen.
6/25/18       #3: polishing CV ...
Do you want to change the sheen, or just smooth it? I love Abralon, wet or dry, for smoothing.
6/26/18       #4: polishing CV ...
Brad
You are right JM customers change their minds. Even though they signed off on Dull sheen it was a different story when it's on a 5' x 6' table top. Rich C. They are satisfied with the smoothness the CV gave them. I'm not familiar with Abralon, what is it and where can I get it. Thanks folks.
6/26/18       #5: polishing CV ...
Put 3 more coats of CV on it in gloss sheen. You're going to need it if you want to polish to gloss. Start out at about 800 grit and work up to 2000 or 3000. Then buff it out. It'll be shiny, might appear cloudy because of the dull sheen under it.
