Subject: Re: Stair tread finish
Stair tread finish
8/14/18
Josh Koschak Member
What are your recommendations for a finish to be used over stained rustic oak stair treads and risers. These will be wire brushed, sanded to 320, stained with SW stain, then sprayed. Thank you in advance.
Josh
8/14/18       #2: Stair tread finish ...
Bona Floor finishes.
8/17/18       #3: Stair tread finish ...
robert johnston
Glitsa and wear a mask, open the windows!
8/17/18       #4: Stair tread finish ...
chris
why are you sanding to 320?
150 is fine
8/17/18       #5: Stair tread finish ...
Josh Koschak Member
On this particular job, I am aggressively wire wheeling the wood but then sanding by hand with 220 and 320 to take the roughness out. It looks rough but is very smooth to the touch and socks will not get caught on the treads if you happen to slide along them.
8/17/18       #6: Stair tread finish ...
You have to look at the finish to see what they request for the final sand. 220 might work for a waterborne and 150 for a solvent, but I think 320 is to fine for most finishes.
After the first coat is put on you can go to 320 to make it feel smooth.
8/17/18       #7: Stair tread finish ...
jmace
320 is way too fine for the raw surface. Like Leo said, you can get there later in the finishing process, but you need open vessel structure and unburnished fibers to promote optimal adhesion for the seal coat. If you choose a floor finish, which is appropriate for a tread, I would pre-finish prior to installation, bcuz floor finishes are designed to stay open a bit longer for better flow and leveling. Not a good scenario for an installed riser. Lace curtains galore!!
