Subject: Re: airless spray systems
8/29/18
Geneh Member
I'm looking for an airless sprayer that will work with laq water or solvent. I was hoping to find one made by Graco but so far no luck.
8/30/18       #2: airless spray systems ...
Nick
My 2 favorite airless pumps for fine finishing are either a Wagner diaphragm pumps
..being the old-timer that l am, l sprayed 1,000's of gallons of lacquer out these pumps in the 80's & 90's (l believe they're called a Capspray ED655 now) and the new-ish Graco GX19. Both come outfitted with hoppers so a lot less paint needed to get finish to the gun and both will spray at a pretty low pressure (for a airless) with little to no pulsation. Combine these pumps with Graco's new low pressure fine finish tip and you have a mobile, fast, fairly efficient, relatively inexpensive finish set-up ( inexpensive when compared to a new AAA or even a top of the line Turbine set-up).
8/30/18       #3: airless spray systems ...
Shane
graco finish pro 2 595 pc
Will spray any latex paint you throw at it or any solvent born laquer that's water thin..... Pump comes with an airless gun and hoses as well as an air assisted airless gun with hoses.... The unit can function in both airless and air assisted airless mode and it houses it's own compressor for AAA... Nice little system. We bought 3 of them in febuary because we had a contract for a casino that's specifically spec'd a particular brand and color formula. We are running in AAA mode with the latex and fine finish tips with excellent results on large and small items for this project. Pricey but it's the right tool for the job. only hiccup has been the pressure cutoff switch on two off the units has failed and has been covered under warranty.... I'm sure they will continue to fail after a few months of use. the pumps have hundreds of hours on them since febuary...
8/31/18       #4: airless spray systems ...
Geneh Member
Thank you both for the info. After talking to a graco rep I'm also looking at hvlp turbine system since the amount I.m spray less than 50 gallons a week.
9/1/18       #5: airless spray systems ...
herb johnson
go with what shane suggested, a turbine gun typically does not have enough atomzing capability, just because you don't spray 10 gallons as day is not a justification for a turbine system in fact it is quite the opposite, imho most sw eqpt people especially at store level don't always get the best advice, stick with what shane suggested
good luck herb j
9/1/18       #6: airless spray systems ...
Geneh Member
Herb get this one the graco rep told me there are some people use a 395 airless for solvent base. I looked it up and found that the motor is sealed. I thought that was playing with fire? I know some reps will say anything to make a sale but wow.
