Subject: Re: Flatline
Flatline
10/17/18
Dan
I’ve been finishing about 20yrs now, never did any flatline work a lot of jobs now ask for that experience I live in New Jersey does anyone know of a school or someone that teaches how to use this type of finishing machine I’m located in central jersey any help wld be appreciated
10/17/18       #2: Flatline ...
chris
check out AWFI. they have different courses and a lot of different equipment.
10/17/18       #3: Flatline ...
Dan
I will check it out thanks
10/17/18       #4: Flatline ...
mauricio poli Member
Hello Dan It is not difficult, it is easier than the spray gun, because all you have to do is to pay attencion on the sizes os the panels, amount of material applied, uv light amount,if it is sanding well or not. I´ve heard that in New Jersey there is a RENNER WOOD COATINGS Distributor, maybe you have to check if they could help you. Look this brasilian movie and then you will have a better understanding. Good luck
https://www.youtube.com/watch?v=0dx82ei0Vj0
10/18/18       #5: Flatline ...
Shane
The machine in the video is a UV roll coater and obvious finishes panels that are flat.... it's basically a paint roller on steroids using UV light cured coating...the buzz word flatline generally relates to reciprocating sprayers which is not like the machine pictured above but rather has multiple guns that reciprocate and spray flat surfaces as well as the edges... leaves a much nicer finish than roll coating.
10/18/18       #6: Flatline ...
Dan
Thankyou very helpful this forum really helped me out
10/18/18       #7: Flatline ...
herb johnson
awfi isn't cheap, why not get to a local machine distributor who handles your brand,
like shane said with all the online videos' that mfg have before i shelled out a lot of money i would persue a , a local or nearest distributor of the machine, b call their tech service line of the mfg,
a local distributor can help you with service which the original person you mentioned i dont belive have that capability of repair
10/18/18       #8: Flatline ...
Dan
Thankyou
10/19/18       #9: Flatline ...
Matt
We just had a Cefla rep in our shop the other day, they sold a flatline locally and we invited them over to say hello and tell us how their machine could improve us.
We aren't pulling triggers on anything just yet but I have no doubt whatsoever that they could teach me all I need to know about buying the right machine for my application, and using it. I wouldn't feel the need to take any general classes about flatline/recip spraying.
But neither would I hesitate to do that if the classes offered were reasonably priced, reasonably local, and would "shoot straight from the hip" about which manufacturers are producing trouble-free, quality machines with good tech support.
