Subject: Re: Water Based Stains and Topcoats
10/17/18
Jarrod
Hi everyone, I work for a small coatings company that produces stains and topcoats. Our customers are finishing companies, we currently do not do retail. However, our company was approached by a large retail chain to supply them with water based stains and water based topcoats.
The target customer is going to be professionals that finish flooring.
My question is, what type of qualities in a stain or topcoat are important to you as a finisher? Easy to use? Fast dry time?
Are there any negative properties that you see in your current products?
Thank you for any input!
10/17/18       #2: Water Based Stains and Topcoats ...
mauricio poli Member
Hi Jarrod
As a chemist formulator I love WB products , so for me it is difficult to say bad things about those kind of finishes.
My last job with WB flooring aplicatión was in a very big house, applying over nogal veener. Three coats in the same day, the final look was a very nice satin look.
Those kind of very rich people who can pay for that want to see and fell the wood. They do not want a plastic felling, as PU products do have.
The only thing I would do better, it was to add a little bit of transparente iron oxide wb dispersion, to put an ambar color, as the NC lacquer does on the wood.
Apply both chemistries side by side on the same wood and you will understand what i am saying.
Doing follow up to this costumer, a few months ago I asked how it was the appearence after two years and he said that the floor is ok, looks great.
I used to work with RENNER WB finishes
10/18/18       #3: Water Based Stains and Topcoats ...
Jarrod
Hi Mauricio
Thank you for the response. I agree, formulating for WB is much easier.
What do you mean by adding transparent iron oxide wb dispersion? Do you use transparent pigments in your stains or you add them to the top coat to have a tinted top coat?
