Subject: Re: Seal Coat over water based varnish
11/10/18
Eric
Customer has requested a high gloss painted finish. I'm using an Acrylic paint with a water based varnish topcoat. Looks great, but unfortunately it isn't glossy enough. Sprayed a coat of Seal Coat over the varnish on the sample and it's perfect. My concern is that while there is no issue with the two adhering to one another, the Seal Coat is a harder finish than the water based varnish, so I am worried about the Shellac cracking. Was unable to spray the Seal Coat directly onto the paint as the alcohol reacted with it and messed up the colour. Thoughts?
11/10/18       #2: Seal Coat over water based varnish ...
Pat
Why don't you just use a waterbased clearcoat in a high gloss sheen? You may be able to get away with the SealCoat not cracking if the waterbased clear is fully cured, but that can take up to a month. Also, SealCoat is not a good topcoat. It's not very tough and doesn't resist spills and household chemicals well at all. Plus, it has an amber tint that will shift the underlying color.
Cheers,
Pat
11/11/18       #3: Seal Coat over water based varnish ...
robert johnston
Pat's answer is the way to achieve a high gloss finish. Several 'commercial' waterborne lacquers are available: MLC,
ICA, Valspar, Lenmar, etc. And, fwiw, house paint is house paint...poor color retention.
Remember to do samples first!
11/11/18       #4: Seal Coat over water based varnish ...
John L
In agreement with last two posts as well. Some of the water based varnishes have elastomeric properties and stretch like crazy rather than break. Probably best not to use a finish that is too hard. Might want to try a single component water based poly such as EMTECH SuperClear 9000 WB Interior Polyurethane with their cross linker. That stuff is super stretchy as well. EMTECH is available at Target Coatings.
What brand was the water based varnish you used?
