Subject: Re: breakaway glaze
breakaway glaze
11/30/18
Kevin Member
I don't have a ton of experience with the breakaway glazes(amazing glaze). On an upcoming job, we are going for the pinstripe look in the details only, and I'm wondering how they would work out of a glazing gun. Any advantages to these glazes in this application, or better to stick with the oil based? Thanks,
12/1/18       #2: breakaway glaze ...
Collin Parker  Member
Website: heritagewoodwright.com
Although its been a while since using the amazing glaze, we have never had much luck with it in the past. I have seen some videos of ppl wiping it off like its nothing but for us it Always clung and etched in much more than we wanted.
If only doing detailed portions with a glaze gun, i assume you have one with the needle tip, then I would go with the vintage alkyd glaze.
12/1/18       #3: breakaway glaze ...
Jim Conklin  Member
Website: http://www.jhconklin.net
Never used a breakaway glaze in such an instance. If the one you use has an acetone or other hot solvent diluent, I would steer away. I second the alkyd solution.
12/20/18       #4: breakaway glaze ...
James Herron
I use oil based in a hair color bottle.
Goes only where you want it and no wiping.
