Subject: Re: thinner
thinner
1/6/19
chich Member
would like some advise on thinning precat lacquer i have HVLP guns and an air assist Mohawk salesman and ML Campbell rep, both of which are professional finishers seem to ignore me when i suggest a viscosity cup they add thinner by percentage and watch it flow off of mixing stick and the atomization is perfect . What would happen if i added too much thinner . I have been painting color
1/7/19       #2: thinner ...
Shane
depends on what your trying to achieve..... Are you reducing viscosity to achieve better atomization? Larger orfices and different pressure could help solve this.... If your reducing you are thus lowering your solid content of the finish as well.... over reducing will lead to your topcoats shrinking back and looking hungry...
1/7/19       #3: thinner ...
mastercabman
I never go over 10%
I use MLC all the time and most of the time I can spray without thinning
If your material is too thick because of cold weather
Warm it up first before you add anything
Adding too much thinner will make your finish look very dull and may not have an even sheen
And you will need to apply more coats
More time,more material,more money!
1/7/19       #4: thinner ...
chich Member
as usual thank u guys So i guess the answer is to increase nozzle size How much air pressure is safe to increase Can i go overboard with the pressure as well?
1/7/19       #5: thinner ...
mastercabman
Why don't you tell us what problems do you have if any and what MLC product do you use?
Also what spray equipment do you use a what size nozzle?
1/7/19       #6: thinner ...
chich Member
thanks again guys i have all C.A.T. products 14.1 air assist 26-101 cap 513,211,613,511,411,313 jets i also have HVLP cougar gun 21-1093 cap 21-1090 1.7jet i dont spray much as you guys can summize but i use Magna claw and magna max
1/7/19       #7: thinner ...
mastercabman
Since you are using a pump,I don't think you need to worry about thinning
Unless your material is really Cold but I suggest to warm it up before adding thinner
I use magna a lot too and use pressure pot/feed system
Occasionally I add flow enhancer but that's pretty much it
1/7/19       #9: thinner ...
chich Member
thanks again mastercabman my shop is maintained at 60 degrees always should i still warm the product up if not what else do i try I have been playing with the adjustments 513 bug enough?
1/8/19       #11: thinner ...
chich Member
i am having a hard time getting a nice wet coat this is with both guns so what should i do rebuild kit coming for the airless but who knows
1/8/19       #12: thinner ...
Shane
that 513 with those products should be just fine as well as using the 411 for topcoats..... reduce 10% by volume with the flow enhancer... 30-35 psi on the fluid side of the pump and around 25 psi pulling the trigger on the gun should be around the sweet spot...…. A bucket warmer/strap heater plugged up to the pail for cooler temps could really help keep your material acclimated just don't go overboard.....
