Subject: Re: Ultra-mat (0% to 5%MAX sheen) advise!
10/4/19
Robert M  Member
Have a customer requested to refinish this bench & a matching dining table so it becomes totally flat-mat, like no sheen at all !!
Tried ( as seen in the below photo) rubbing out the actual finish with red 3M pads, but….not enough as per customer ( still to much glare !)
SO !!
Any advice on who makes a 0% ultra mate water base lacquer !?
Or any other “trick” to apply over so the outcome is 0% sheen ??
Thks
10/4/19       #2: Ultra-mat (0% to 5%MAX sheen) advis ...
TonyF
Robert:
I personally like the Target Coatings flat sheen finishes, which I think are 15 sheen. They give a good looking, uniform low sheen, which you may be able to augment by using a flatting agent.
You can sometimes get Jeff Weiss, the company founder and chemist, on the phone, or if not he will answer questions sent to him via email. I would ask about what you want to do, or perhaps just try the flat sheen first and see what happens.
Part of the problem in rubbing out a rough surface like that is the lack of sheen consistency. You can try the flat sheen finish, which will give a uniform sheen, and may be all you need. If not, perhaps Jeff Weiss can advise you as to the saturation point of flatting agent in a finish.
Hope this helps.
TonyF
10/4/19       #3: Ultra-mat (0% to 5%MAX sheen) advis ...
DeanV Member
Try modern masters dead flat varnish. It is a waterborne. Most mattes we have tried are more like and eggshell paint sheen. This is flatter than that. It has been a long time since I used it, so I don’t recall exact sheen.
10/4/19       #4: Ultra-mat (0% to 5%MAX sheen) advis ...
CraigM
Milesi makes HGA 19, which is a natural effect dead flat waterbased poly. I use the solvent version which is great. I think Renner makes a flat sheen wb as well but i've never sprayed it.
10/4/19       #5: Ultra-mat (0% to 5%MAX sheen) advis ...
Robert M  Member
thks Craig, Melesi is much in the range of what I also use ( ilva, from IVM too).
Thanks for this, will check it out !!
And for the Target of this world, no offence and with ONLY great respect, but, it's just not for me ....anymore !
10/5/19       #6: Ultra-mat (0% to 5%MAX sheen) advis ...
John Member
You can buy WB flatters from Hood Finishing, and adjust the sheen of an WB product you have. I've used it several times and it's always worked well. It does tend to drop out of suspension in a few hours so frequent stirring is a must.
John
10/7/19       #7: Ultra-mat (0% to 5%MAX sheen) advis ...
Shane
Milesi natural effect is going to get you what you need there
10/7/19       #8: Ultra-mat (0% to 5%MAX sheen) advis ...
Tyler
Sivam Wood Effect works great.
It's a 2k poly true 0 sheen, 3 coats and you cant tell it was ever finished.
10/7/19       #9: Ultra-mat (0% to 5%MAX sheen) advis ...
Gary
Sherwin Williams made me a 5 sheen in both Kem Aqua Plus and Sayerlack
10/8/19       #10: Ultra-mat (0% to 5%MAX sheen) advis ...
Robert M
Thks you all for this info, will defiantly help !
To Tyler :
While searching, could not find this 2k poly at 0% from SIVAM ?!
Could you share the product series or code so I may look in to it ?
10/8/19       #11: Ultra-mat (0% to 5%MAX sheen) advis ...
Tyler
I attached the PDF here for you. Has product number etc. I order it from Richelieu.
1460898.pdf
10/8/19       #12: Ultra-mat (0% to 5%MAX sheen) advis ...
Robert M
Tyler…..here’s a funny (or say pitiful ) anecdote !
After reading your reply on Monday and aware Richelieu carries SIVAM, I took the chance on calling the “so call finishing rep” and ask if he could tell me more about this SIVAM special Wood Effect (not knowing we’re taking about the LFE607?...then) !
Well, turns out he had no clue on what I was talking about !!
Bear in mind, I’m in Canada and was calling their Montreal head office !
Long story shorten, he call back not to long ago today to tell me…..sorry, they do not sell that one !
Imagine the laugh I gave him …after reading your reply & link !!
Goes to say……the bigger the box, the more their lost !
Part why I tend to stick to a finishing company ( say like Milesi from IVM) VS a…..well, jack of all trade and master of none being just a huge box offering too many bands…..to share holders loll
Thanks and….enjoy a good laugh too !
10/8/19       #13: Ultra-mat (0% to 5%MAX sheen) advis ...
Tyler
That's a shame, as it's a great product, I have been fortunate to have a great finish rep through richelieu, but I guess I am of the few not many!
10/9/19       #14: Ultra-mat (0% to 5%MAX sheen) advis ...
the google Member
have you guys tried ilva's velvet diamond? sounds very similar to this sivam product.
we ran into problems with the velvet not wanting to dry properly with air temps below 68*. it also could show up white if the end grain wasn't thoroughly sealed. i wander if the sivam performs similarly.
10/11/19       #15: Ultra-mat (0% to 5%MAX sheen) advis ...
Robert M  Member
TYLER.....ya, your "say" lucky !
About luck, may I ask you to share the Richelieu sku on this SIVAM so I may tell them that's the one I want to try !
Thanks again ;0)
10/11/19       #16: Ultra-mat (0% to 5%MAX sheen) advis ...
Tyler
Here is a snapshot of Richelieu's website with the product numbers.
View higher quality, full size image (1450 X 667)
10/11/19       #17: Ultra-mat (0% to 5%MAX sheen) advis ...
Robert M  Member
Much appreciate this TYLER....
As you can see, it's MIA around here !?!
But, with your screen shot, I can now have a valid argument it is in there system, just maybe not in Canada ??!
O-well, I'll see with them, if not, will just go with MILESI ;0) !
Thank you much for your assistance, I'll post the outcome later.
Cheers ;0)
View higher quality, full size image (1600 X 794)
