Kremlin/Water Base Primer
1/7/15
Joe Member
Guys,
I have 2 EOS pumps one I run a precat lacquer through with a pail mount agitator and I can leave this idle for days with no issues spin the agitator pop on the tip and cap "spray away"..... The other I use for priming only with a great WB primer from Chemcraft. If I leave the primer in line overnight with the tube in solution and the gun trigger closed the primer solidifies in line. Both Reps have no answer to why ????????
1/7/15       #2: Kremlin/Water Base Primer ...
herb johnson
if its single component, the primers usually have a high filler solids that are most likely falling out of suspension., i would flush the lines with water , leave water in it, they start in the am, the pumps don't hold that much fluid, better than losing fluid lines,
if you want to recover a fluid line, reverse the fluid line meaning put the pump end on the gun end and vice versa
i have saved a lot of money doing that, besure to remove the spray gun
good luck
herb j
1/8/15       #3: Kremlin/Water Base Primer ...
RobertJ
I echo Herb's solution. I spray with a 10-14 pump and MVX gun. I was spraying Valspar's Zenith Universal Amber Primer(H2o) and did not thoroughly clean my fluid hose....the following day, tried to spray, nothing comes out. Thought my pump was broken. No, the primer had completely congealed in the hose.....plugged it up completely. Had to purchase a new fluid hose. Hence, I believe you have to clean with water first, followed by Denatured Alcohol to get the fluid hose clean. Who said spraying waterborne was chemical free!!!
1/18/15       #4: Kremlin/Water Base Primer ...
Brian T
I've had this issue with both Kremlin 10-14 and the newer EOS pumps with the same Chemcraft primer and other water based finishes. It hardens where the fluid line to the gun leaves the side of the pump housing. It has to be the fittings that allow it to harden.
I also spray the primer out of 2 Graco Merkur pumps which are very similar in design to the kremlins with no issues at all.
I plan on buying a 55 gallon pail mount kremlin with an agitator as a built in system but only when they resolve the current issue. It's not the kind of thing you break down every night. The sales rep is working with Kremlin on a solution. My guess is they will copy the GRACO design which has never had an issue.
1/18/15       #5: Kremlin/Water Base Primer ...
herb johnson
interesting read, fittings cannot cause a material to harden unless a brass fitting might come in contact with a wb, even a galv fitting wouldn't cause an issue, i might be a dead spot where the pressure of the pump is shearing out the solids, i think what really is happening is the solids are falling out of solution much like the old lacquer days when you had to stir the finish to get the solids back into the material, very interesting that the graco doesn't do it with the same material, again thinking of dead space and sheering
will have to keep checking on this one
1/19/15       #6: Kremlin/Water Base Primer ...
Brian T
Herb,
I was not referring to the composition of the metal fittings but more to the ability of them being air tight. I believe there is a weak point in the fitting that allows air to somehow get to the material. It only happens at the fluid outlet from the pump when the pump is kept under pressure.
The material itself could be sheering but it's hard to say. When you take the fitting off you end up cleaning out a hardened plug. It's identical on the 10/14 and EOS except it seems to even be a little worse on the EOS fittings. The material seems to harden further down the line.
I wonder if anyone has had this problem with any other pumps other then the Kremlin?? Binks, Falcon Etc.
