Finishing pumps and guns
1/14/15
James Wilson Member
We are a Big production custom cabinet shop in ca, im looking in to new hvlp pumps and gun for the shop conversion varnish, im looking at the binks mx1212 and graco, i was wondering if any one had a opinions on these we do run 16 hours a day so the equipment does get alot of use, Thanks
1/14/15       #2: Finishing pumps and guns ...
Tom C
And the reason you don't use AAA ? is....
Kremlin ,CAT , ect...
4 man shop &1 full time finisher. 3 Kremlin10-14 units .
1 for sealer 1 for CV topcoat ,1 for pigment. And 1 CAT AAA H2O for white acrylic primer....
Just the amount of transfer efficiency you'll gain spraying that much will buy them.
If I sprayed that much CV ,I would get a catalyst ratio system.
How many gallons a day are you mixing by hand ?
1/15/15       #3: Finishing pumps and guns ...
James Wilson Member
We are looking at getting a catalyst ratio system once we get every thing in place, we mix about 50 to 100 gal a day,
1/15/15       #4: Finishing pumps and guns ...
chris
how many sprayers do you have?
last year i upgraded to a graco promix system and used the kremlin 10-14 pumps i already had.
I am using this for 2k urethane.
1/15/15       #5: Finishing pumps and guns ...
James Wilson Member
I have a total of 8 sprayers 4 per shift
1/15/15       #6: Finishing pumps and guns ...
chris
have you thought about an automated flat line system?
1/15/15       #7: Finishing pumps and guns ...
James Wilson Member
We have had one in the pass and to my understanding it was not a good fit
1/16/15       #8: Finishing pumps and guns ...
chris
i would look into getting air assist pumps which can later be used for your catalyst mix system.
I can give you contact info for the sales rep I used if you need. has lot of experience with Kremlin and graco.
1/28/15       #9: Finishing pumps and guns ...
rick morehou Member
In a Cabinet Shop environment a Spray Man will get a excelent pattern-control and results out of an old Model69. All this fancy-assed stuff does not make a fine finish... Quit Blaming the CUE STICK, if what you do don't work, adjust.. If you need to measure your thinner you are telling yourself that you don't know what you are doing. Save your Money and HIRE a PROFESSIONAL FINISHER Their wage should be one of the highest and the Boss should be happy to pay and have that kind of talent. Rick M
1/29/15       #10: Finishing pumps and guns ...
chris
try reading the original post.
He is looking to upgrade to increase efficiency and speed.
nowhere did he mention having problems with his finish quality.
If you want to spray 100 gallons of CV a day with a cup gun go ahead.
And yes I am a professional finisher.
