Rough lacquer -- 0 --
1/20
I recently switched from bin shellac primer to mb Campbell's lacquer primer and have noticed a problem we use mdf panels and the finish is very rough to touch. I tried sanding with 220 but same thing and they are not all same some spray smooth but most are very rough what am I doing wrong thanks lads
1/21 #2: Rough lacquer ...
Website: http://s51.photobucket.com/albums/f386/jcquack/Fur...
that sounds like it may be drying to fast.
Use a real slow thinner, in warm conditions
a little retarder helps.
I don't even use lacquer thinner anymore,
I switched to automotive urethane reducer,
the slowest one made.
I also thin lacquer at least 100% to get
a smooth finish, sometimes 150%
1/21 #3: Rough lacquer ...
Website: http://subercustomshutters.com
I agree with Jim, fast drying finish means you are coating it with a fine grit from some of the finish being dry as it hits your surface. Retarder and the correct thinner will make a difference, and finding the correct ratios.
Mdf can also present problems on the cut or routed edges, but should be alright on the flat areas, if you are using a good primer. You may have to repeatedly prime and sand the edges, before painting. Mdf has a roughness on the edges similar to grain raising. I find when we size the edges, with a 50:50 mix of wood glue and water, let dry, then sand, we can go ahead with our normal prime and paint procedure. We apply the sizing with a glue brush or similar small paint brush. Be careful about getting this mixture on the flat area, it can cause a slight swelling. We wipe the flat area dry as we apply the mixture to the edge.
1/21 #4: Rough lacquer ...
Thanks lads could ye tell me what type and make of retarder I should use And thanks for the responses. Ye have been great help thanks tadhg
1/21 #5: Rough lacquer ...
Wow, I just reread your first post. If the primer is being a problem, I have never used retarder in primer. I always worked out primer issues with thinner and gun adjustments. I do remember finding that all lacquer thinners are not the same. Some are hotter than others and can cause different results with primers. Be sure you are using a thinner rated for your primer.
If paint is a problem, my long ago lacquer experience is limited to a brand I no longer remember, and currently I only use Sherwin Williams brand. They offer two different strengths of retarder, the one I use is referred to as a super-retarder. I probably only use about 1 1/2 to 2 oz when mixing 1 quart of paint, plus some thinner. If you are interested in the Sh Williams information, I can get it tomorrow when I go in, plus the mixing ratios. If you use another brand, be careful and experiment before using on your product. Too much retarder is a whole new problem, I have had shutter orders not dry for several days when using too much.
0 --
Buy and Sell Exchanges
Lumber Exchange
Machinery Exchange
Classified Ad Exchange
Forums
Adhesives Forum
Business and Management Forum
Cabinetmaking Forum
CAD Forum
CNC Forum
Professional Finishing Forum
Forestry Forum
Commercial Kiln Drying Forum
Sawing and Drying Forum
Solid Wood Machining Forum
Veneer Forum
WOODnetWORK
Galleries
Project Gallery
Sawmill Gallery
Shop Gallery
Shopbuilt Equipment Gallery
Other Resources
Industry News
Video Library
Repeated Forum Abuse:
Forum Posting Form Guidelines
Your Name
Your Website
E-Mail Address
Subject
Thread Related File Uploads
