Binks rapitor AA1500 about 13 yrs old
1/26/15
Ive had my airless air assist pump system for about 13 years. Have not been using it nearly what one would consider full time.
I've been having some issues:
1) when i start to spray, after a few secs and the pump makes it's "sound" of acuating up and down, it loses air pressure (the spray stops coming out for a fraction of a second, which could be a real nightmare on a dining room table top or larger pieces.
2) it's not spraying a full 10" pattern that it should be, as u can see in the pic. After spraying a few parts, it got better, but clearly, it's not spraying the way it should
I took most of my pump apart and have the lower half soaking in thinner to hopefully clear up and clean out the inside where the material runs through. There was a type of grease on the rubber gaskets that I want to buy more of and put it on. Anyone know what type of grease this is and can i buy it at an auto parts store?
I keep my tips soaking in thinner when not in use and clean out the filter in the fluid line at the bottom of the gun after each use
Any thoughts on these issues? My sir is set to about 20-25 and fluid is set to 40
Im spraying a 2 part arcrylic polyurethane (2k) by Milesi with a .015 by 10" fan tip
1/26/15       #3: Binks rapitor AA1500 about 13 yrs o ...
herb johnson
be sure to check your upper and lower ball check, using a two part the ball can get stuck and not move freely
for lubricating the air motor get teflon grease, not silicone grease
also inspect the siphon hose assy for any crackes
good luck
herb j
1/26/15       #4: Binks rapitor AA1500 about 13 yrs o ...
Heres the pic i forgot to include
1/26/15       #5: Binks rapitor AA1500 about 13 yrs o ...
herb johnson
also looks like you have a clogged tip with all of those stripes
1/26/15       #6: Binks rapitor AA1500 about 13 yrs o ...
I keep it soaking in thinner and i use the really fine micro needles to clean it from kremlin. What else can i do?
1/26/15       #7: Binks rapitor AA1500 about 13 yrs o ...
herb johnson
here is what i do, fill the pump with solvent, aftert you prime it turn up the pressure to about 80-90 psi start triggering the gun on off on off etc will help power clean the tip
helps me keep the tip cost down when my stupid painters don't flush the pump out right
good luck
herb j
1/26/15       #8: Binks rapitor AA1500 about 13 yrs o ...
Leo G
High pressure spraying with solvent is one way to clean things up. Another is to use an ultrasonic cleaner with a line cleaner as a cleaning solution. You can boil the tip and a lot of times that will get rid of some stuck gunk.
But after 13 years, it sounds like you just need a new tip. They wear out.
