Finish For Cedar Cabinets. -- 0 --
2/16
I am in the process of re-finishing some 50+ year old Cedar Kitchen Cabinets.
After using a belt sander to remove 50+ years of cooking goo, and whatever other finish they may have had on them in the past. The Lady owner just LOVES the awesome light color and pretty grain they have on them when un sealed. Just sanded.
But even after just applying a neutral colorless sanding sealer to them,, they get a LOT darker. see the image.
Is there any way that I can seal them yet keep the lighter color. in 50+ years, if there is,, it is news to me. anyone?
View higher quality, full size image (1536 X 1152)
2/16 #2: Finish For Cedar Cabinets. ...
clear waterborne lacquer....the best is from
ICA!! Only the Italians produce a 'natural' wood coating. Trust me, I have tried to find one made in the USA....next best is MLC Agualente or Zenith by Valspar.
Forget the shellac!
2/16 #3: Finish For Cedar Cabinets. ...
Where can I get some of this here in the states?
2/16 #4: Finish For Cedar Cabinets. ...
Another supplier of quality waterborne finishes is Target Coatings. Their super clear poly is a good choice - see link below.
Target Coatings water-base finishes
2/17 #5: Finish For Cedar Cabinets. ...
ICA Coatings has lots of distributors in the US. Link attached.
ICA Coatings
2/17 #6: Finish For Cedar Cabinets. ...
We are using the ICA waterborne sealer and top coat.
Its for sure the best clear coat waterborne I have seen
It requires some fine tuning of the gun and the employee but its so worth it.
2/17 #7: Finish For Cedar Cabinets. ...
If you are going to try WB, then take a wet cloth and rub it into a test piece and that is going to give you somewhat of an indication what to expect. Most likely even WB are going to end up darker than you want and that is part of the process of the coating being absorbed into the cedar.
Not sure if this will work or not but what you are trying to do is add a protective coating without having it penetrate into the wood fibers and that is tough to pull off. I would try to set up my spray gun to mist several light coats on the surface to just dust it and see if you can get enough of a layer on there to seal the surface and prevent future coats from soaking in, then use the products above. Use a dull sheen.
2/17 #8: Finish For Cedar Cabinets. ...
I just tried just some plain water as suggested to see what the tone would be like.
It ended up a little lighter, Barely than the zinner. The zinszer was still a little darker, but the difference is sooo small that the average person probably wouldnt even notice it. So I guess I'm stuck with them as it is. OR.............
Being Cedar,,,, And the rest of this house inside is Cedar, "No finish at all, I wonder how long they would stay looking like they do, if I was to sand them clean, and polish samd them all the way down to 400 or 600 grit and then just left them bare, How long do you think they would stay this way. This is something I have never ever done also. hmmmmm?
Joe
2/17 #9: Finish For Cedar Cabinets. ...
" Cooking goo " on soft and raw Cedar does not sound appealing.
2/17 #11: Finish For Cedar Cabinets. ...
Thats true too, hmmmm?
2/17 #12: Finish For Cedar Cabinets. ...
i get this request alot. customer wants the wood to look like it does when theres no finish applied. the closest ive come is with dead flat water white lacquer. I use t67f6 vinyl sealer diluted 40% to seal it. Sprayed on very lightly. Just enough to pass as a coat. Then i add 8 ounces of universal gloss modifier paste per gallon of t77f83 water white lacquer. Looks unfinished... but not sure how it would hold up in a kitchen.
2/17 #13: Finish For Cedar Cabinets. ...
Joe,
Wetting the wood with water will not give you a good representation of how it will look if you apply a waterborne finish. Before it evaporates, water will make the wood look similar to the result a solvent based clear coat will produce.
Using a waterborne finish to retain the natural look of the wood as much as possible is a good choice. I'd recommend you do a sample to evaluate the results.
Kevin's recommendation to use a flat finish is a good approach to make the wood look unfinished, but solvent based finishes do wet the wood fibers well and make it look darker. Many waterborne finishes do not wet the wood as well and the color is more natural. Making waterborne finishes produce the "warm" look of solvent based finishes is a specific characteristic that the formulators have been making improvements on for a number of years.
2/17 #14: Finish For Cedar Cabinets. ...
I've contacted the couple companies about trying to find some or samples I don't want a whole gallon yet, or would need even. so anyone make a suggestion of something like from menards, home depot, sherwin williams etc.?
Joe
2/17 #15: Finish For Cedar Cabinets. ...
Check with your local Sherwin Williams to see if they have Kem Aqua I have used it a number if times on furniture with good results (the "dull rubbed" sheen looks good). If you use it with the sealer, it passes KCMA testing for durability (see attached data sheet).
KemAquaPlus.pdf
2/17 #16: Finish For Cedar Cabinets. ...
But then again if i use it with that sealer, then I'm back to dark again.
Joe
2/17 #17: Finish For Cedar Cabinets. ...
The sealer is also waterborne. Sampling is your best bet at this point.
2/18 #18: Finish For Cedar Cabinets. ...
Joe,we at Milesi High performance Italian wood coatings can offer a great finish for your project. Feel free to contact me at www.milesi@milesi.us
2/18 #20: Finish For Cedar Cabinets. ...
Drop me an E Mail
nss@mwt.net
2/22 #21: Finish For Cedar Cabinets. ...
Final Up-Date:
Owner finally decided to try going au natural.
In other words sand them down, and leave then as is. And see how long they stay nice looking. Should be interesting. The whole house inside is un finished Cedar too and it is only slightly darker than the sanded stuff. Even after all those years. So should be an interesting experiment.
Thanks everyone for all the sugestions.
Joe
0 --
Buy and Sell Exchanges
Lumber Exchange
Machinery Exchange
Classified Ad Exchange
Forums
Adhesives Forum
Business and Management Forum
Cabinetmaking Forum
CAD Forum
CNC Forum
Professional Finishing Forum
Forestry Forum
Commercial Kiln Drying Forum
Sawing and Drying Forum
Solid Wood Machining Forum
Veneer Forum
WOODnetWORK
Galleries
Project Gallery
Sawmill Gallery
Shop Gallery
Shopbuilt Equipment Gallery
Other Resources
Industry News
Video Library
Repeated Forum Abuse:
Forum Posting Form Guidelines
Your Name
Your Website
E-Mail Address
Subject
Thread Related File Uploads
