finishing wood top debate
2/24/15
Dan Hueber
Website: http://www.theVCollective.com
We completed a kitchen of about 60 lineal feet of 2-1/2" thick walnut tops. we did mitered corners at the turns, not butt joints.
There is a debate in the shop on finishing the tops where one camp wants to spray coats of clear post cat lacquer on the bottom and 4 to 5 coats of Waterlox rolled and brushed on the top side.
The other view is that top and bottom should have the same number of coats of the same product so everything remains balanced on moisture exchange.
Any experience with this or opinions?
2/24/15       #2: finishing wood top debate ...
shenendoah
always balance the coatings especially if the boards are 4+" wide. After 40+/- years of doing this, I firmly vote for the other view. One can spray waterlox by the way.
2/24/15       #3: finishing wood top debate ...
Installation will be the most critical factor, but I think you will regret the miter joints. That's a lot of wood movement to deal with, there should be huge slots where mounting screws go in. That said, I would normally use the same finish top and bottom. BUT, Waterlox will stink for a long time when trapped in a box. Those cabinets will get a rancid oil smell in no time, and hold that smell. If you use solid top cabinet boxes, no problem.
2/25/15       #4: finishing wood top debate ...
Regarding those long miters, think about what will happen if the countertops swell cross grain by 3/8". Your perfect corner will change by about 1.5 degrees - will open at the long points of the tops if they are allowed to freely move.
If the tops are firmly held and not allowed to open at the joint, or swing the legs open a bit, then the fibers will all crush where they are compressed and remain there until the cycle reverses itself and the top wants to contract back a bit. Then the joint will open.
I agree with the same finish, same amount, both sides. Woodwork is not a Democracy.
2/25/15       #5: finishing wood top debate ...
Bill in Oregon
I agree with rich, Waterlox will stink up the inside of the cabinets for a long, long time.
