Satin Finish -- 0 --
2/25
I had to put a clear coat over some doors with wb paint on them. I used Minwax polycrylic satin sprayed with hvlp conversion gun. The polycrylic sprays out fairly well and looks good wet at first, but every coat I've had problems drying with dust nibs, lint, pinholes, bubbles, orange peel, etc.
I tried rubbing these out to fix the problems starting with 320 on RO, then wet sand with 400, 600, 800, finally rubbing with 4/0 steel wool with murphys oil soap as a lube. I didn't realize the steel wool scratches would be so visible and I don't like it with this being a solid painted finish. I tried an auto scratch remover, and it helped some, but brought the sheen up way too much also.
I sanded back with 320 again and recoated the doors and got a much better finish off the gun, but there are still some imperfections, dust nibs, and sheen irregularities that I was hoping to remove without putting scratches in the finish or changing the sheen in spots.
Could I use a power buffer and some type of compound to wear down the nibs and produce an even, satin sheen? Would abrading to a higher grit like 2000 make the scratches invisible to the naked eye and still give a satin finish? I really want to maintain the off the gun look to match the rest of the job; will I just have to live with the imperfections?
2/25 #2: Satin Finish ...
You could try the same sanding procedure, except rub with Scotchbrite pads instead of steel wool. Try the white pad with different grits of rubbing compound. If this results in too high a gloss, try the gray pad.
2/25 #3: Satin Finish ...
Off the gun and a polished finish will almost never look the same. Even if they are classified as the same sheen. There is a different look to each of them.
2/25 #4: Satin Finish ...
WB finish 101, never use steel wool. You'll very likely has little rust spots, and other issues. Finishing 102, never buy consumer grade products from a big box store. Try Target or General Finishes for your supplies. You may be applying too heavy of coats of finish and improper nozzle size. Pretty sure Minwax doesn't give film thickness specs because a home owner doesn't have any idea what that is about. Polishing is not the way to flatten a finish, you need to use a flat backed abrasive. Like hard pad on a sander, or block sanding. Abralon is okay after you get the finish flattened to adjust the sheen.
2/25 #5: Satin Finish ...
I notice that in addition to the line of 3M scotchbrite pads they also have different finishing pads like this white final finishing pad.
Link
2/25 #6: Satin Finish ...
Does anyone think those 3M white final finishing pads would get rid of the dust nibs without affecting the satin sheen?
I didn't think the steel wool would leave rust spots as the finish had already dried for several days before I started abrading, and I was using the sandpaper backed by cork block to flatten before using the steel wool with oil soap to get to the satin finish. I didn't intend to use it to sand between coats of wb finish as I was aware of the rust issue.
When I decided the look was not right, before I recoated, I sanded again with 320 on a RO and cleaned the surface well to make sure there was no steel wool debris.
2/25 #7: Satin Finish ...
Rich,
You're right, I think a lot of my original problems were laying on the polycrylic too thick; btw, I was using a 1.4 nozzle.
On my final coat I added a little alcohol to thin and a drop of dish soap hoping to decrease the surface tension and relieve some of the pin holing, which I wasn't sure were because of air bubbles popping or fish eye.
It looked a lot better, now I'd really be glad just to knock off the dust nibs so it feels smooth. I just don't want to alter the "off the gun" look too much if possible.
I'll probably just leave it alone this time and experiment some more with the scotchbrite pads and higher sanding grits to see if I can get a rubbed/polished satin finish that somewhat resembles a sprayed on finish.
Anyone seen the satin automotive finishes and know how they're doing those? I couldn't imagine there being a visible scratch pattern on a car.
2/26 #8: Satin Finish ...
You can't use any type of pad to buff off imperfections, they have to be cut off. White pads are so fine, it is hard to see them do anything. It would take a day to remove bumps with them by hand. Abralon after fine wet sanding does it, but you don't seem to like that idea. Have you really looked closely at a car paint job? It would not pass for furniture finish by any means. Orange peel abounds! The sheen they get is from the gun, but a computer controlled gun at that! Please don't randomly add liquid to the finish. You have no idea what you are doing to the chemistry. Future cracking, soft spots, etc....
2/26 #9: Satin Finish ...
Rich, I've been reading this forum and the knowledge base for for a number of years and it's actually where I came across the advice of adding a little dish detergent containing a surfactant to decrease a waterborne finish's surface tension to temporarily relieve a fisheye or pin holing issue as well as using DNA to thin to get it to level out a little better.
I realize that it might not apply to polycrylic, but I was willing to give it a shot this one time since I was only doing a few doors; hopefully it won't cause any issues, but I know I'll hear about it if it does.
Sure, I didn't like the look I got from going through the wet sanding to 800 and finishing with 4/0 steel wool, but I stopped experimenting there.
What grit would you suggest sanding up to and what abralon pad to get a satin sheen without it looking scratched or like brushed metal, if it's even possible? Thanks.
2/27 #10: Satin Finish ...
I would stop at 600 grit wet sanding, then maybe 500 or 1000 or the Abralon. I suggest you get an assortment so you can judge the sheen. Use a little soapy water for lube. There is no visible marks after using even the coarsest 180 grit Abralon. It has a foam backing, so no visible scratching, just different sheen levels.
2/28 #11: Satin Finish ...
If you spray the coatings on the door/doors in the same position they will hang, its less likely to get dust falling down upon them.
Nibs and drips and stuff and junk and crud and crap need to be removed via a block that has sandpaper wrapped around it.
Without the block your just scooting right over the nibs and the drips and the.....
My apologies if the name of a Law Firm happens to be.. Nibs and Drips and Stuff and Junk and Crud and Crap.
2/28 #12: Satin Finish ...
I don't know if it'll work on waterborne I use a trick to get rid of some plicks.
Use a paper back and rub the area. It has a grit of about 2000. I use it to get rid of overspray if it occurs. It works on rough spots too. Won't work magic but it will take care of a lot of things. Waterborne might not be hard enough to not get scratched though. I use this trick when using CV.
0 --
Buy and Sell Exchanges
Lumber Exchange
Machinery Exchange
Classified Ad Exchange
Forums
Adhesives Forum
Business and Management Forum
Cabinetmaking Forum
CAD Forum
CNC Forum
Professional Finishing Forum
Forestry Forum
Commercial Kiln Drying Forum
Sawing and Drying Forum
Solid Wood Machining Forum
Veneer Forum
WOODnetWORK
Galleries
Project Gallery
Sawmill Gallery
Shop Gallery
Shopbuilt Equipment Gallery
Other Resources
Industry News
Video Library
Repeated Forum Abuse:
Forum Posting Form Guidelines
Your Name
Your Website
E-Mail Address
Subject
Thread Related File Uploads
