re color kitchen cabinets
2/14/15
tom Member
One of my customers asked me today if we could change the color of her kitchen cabinets. Told her I would get back with her on that. They are factory cabinets from Merrill with the typical factory finish.Color is
like a golden on maple wood.She wants a off white.Would sanding at 180 grit,then a vinyl primer and finish with the pigmented lacquer.Looking for suggestions and if anyone has done this. This would be the first one for me.
2/14/15       #2: re color kitchen cabinets ...
David Yurk  Member
Website: http://www.crockettscabinetry.com
We have done some work like this and had some disastrous results. Now when people ask me to do jobs like this I run, not walk, away. They are fraught with peril, especially if you have no experience or training with this particular kind of work. If you do take it, consult with your finish supplier or anyone else who can give you insight. Surface prep is critical and if not done correctly, you could be opening up a pandora's box.
2/14/15       #3: re color kitchen cabinets ...
Leo G
Ask then what they clean the cabinets with. If anyone mentions Pledge then flat out refuse to do it. It will be a nightmare.
Otherwise a white vinyl sealer and then a coat of paint should do. But onsite painting can be very tedious. Whatever you think you are charging for the onsite painting, add 50%
2/15/15       #4: re color kitchen cabinets ...
Nick
I've done lots of jobs like that and can second some of the remarks: prep is key; make a test on the back of a lower door or drawer first to see what you might be getting yourself into, then clean (the importance of a clean substrate can't be overstated!), sand, prime and finish...Lately I've switched over to WB finishes for onsite re-dos for the obvious reasons...low voc's, less odor, not flammable and compatible with most finishes you'll be going over (no danger of lifting the old finish)... that's not to say they are fool proof as stuff can still go wrong with WB's as well.
And what Leo said: it's time consuming; taking off and replacing doors and drawer fronts, hauling them to the shop and then bringing them back, masking and possibly dealing with stuff in the cabinets add up time wise in a hurry.
2/15/15       #5: re color kitchen cabinets ...
tom Member
Thanks for the info everyone.
Now for the guys that have done this before and have had good results,what is the process you use and products you used.This is hard to bid also. The doors I will take back to my shop but will have to do the face frames onsite.
2/15/15       #6: re color kitchen cabinets ...
Robert Member
Scrub down quite well with Paint Thinner and a Purple Scotch Brite Pad. Repeatedly rinse so you don't end up transferring the goo elsewhere.
Yes; bidding is hard.
2/15/15       #7: re color kitchen cabinets ...
Dave Edgerton  Member
If it were me and we have done what others have said before, I would now just tell them I would replace the doors with new and reface with 1/4 solid wood and restain if face frames, add end panels and new doors. less hassle with old finishes.
2/21/15       #8: re color kitchen cabinets ...
Sean
Website: http://www.jacksonswoodfinishing.co.uk
I'vef done quite a few kitchen strip/refinishes and of course without a doubt the fixtures are what take the time to fully clean and mask up. I normally charge for 2 days labour even if it looks like 1.5.
Masking is king, big rolls when necessary. I use a HVLP system so overspray is fairly minimal. Can't remember the last job that I had overspray probs. There's always the barrier primer route if you don't want to strip after cleaning down the substrates but obviously samples are the way to go, not winging it! Tell the customer it's probably going to smell bad and the kitchen is going to be wrapped up for a day or son. Of course WB products are low odour. I use AC lacquer (CV) and make sure they know it needs ventilation and could be uncomfortable to be around - but that's just my way.
Sean
2/26/15       #9: re color kitchen cabinets ...
Chaim Gottesman
Website: https://www.flickr.com/photos/chaimgottesman/sets/
I have redone several kitchens and prep is key.
another factor is like Leo said, what they use for cleaning products.
I recently refinished cabinets which I had already refinished after the client ruined the finish on them after a year or so.
unfortunately they seemed to be cleaning the doors with some nasty solvents and ammonia products.
Of course I had warned them to only use a sponge of soft cloth with a mild detergent to clean with (no scrubbing either).
In any event It was a nightmare cleaning off the residue and respraying.
BTW the finish the client wanted was a latex paint so it was doubly disastrous.
Always put in writing clear cleaning instructions so there is no claims of "you never told me that!"
Chaim
