Reducer for Verde Chiaro
3/3/15
Kevin Member
I'm having problems with pinholes in my verde topcoat. It is flashing off WAY too fast. I thinned 5% with the medium reducer. I would now like to up that to 10 or 15% but am wondering if that is too much and if retarder would be better in this situation. What are you other verde users doing to reduce? Thanks
Kevin
3/4/15       #2: Reducer for Verde Chiaro ...
Kevin
have not used that product but i would suspect your problem to be in the application. Try lighter passes. This will allow the product to sink into the grain without entrapping air.
3/4/15       #3: Reducer for Verde Chiaro ...
shenendoah
At least 4 things may be going on. 1st is that you may be putting on too much material and that it may be too viscous. 2nd may be that you are laying down too much sealer(and possibly not reduced enough if at all!) and not cutting or leveling it enough. 3rd may well be your solvent choices and percentages. One can easily reduce 10% with fast or medium and 5% with slow and spray a standard box coat of 4-5 wet mils. the fast /medium will kick out fairly quickly, while the slow hangs out leveling the coating. 4th would be the amount of air going across the face of the sprayed product, and the heat of the area can highly impact flash/dry. The greater the air flow/heat ratio the greater the need for the slow reducers. 5th could be a combination of the above. 6th anyone?
3/4/15       #4: Reducer for Verde Chiaro ...
Kevin Member
Thanks for the responses. This morning I upped the reducer from 5 to 10% and that made all the difference. Flowed out great, except for a couple of spots. These spots had what I assume is trapped air rising up, and it actually blew a bubble in the finish. Never seen that one before.
3/9/15       #5: Reducer for Verde Chiaro ...
Brian T
Yes, that's common with polys. We went through the same problem a few ago. I explained to one of my finishers that you need to spray lighter coats and get your build with more coats. It only happens on open grained woods.
We usually thin the chiaro 10%, acrilico 5%. Thinning will not stop the entrapment of air in wood grain but it will allow the finish to flow deeper into the grain.
